#1 |
Member#: 295857
Would like to know which brands to get for those parts. Here's what I'm planning:
head gasket: metal, FelPro valve cover gasket: whatever material, FelPro timing belt: Subaru pulleys: Subaru H2O pump: Subaru Can I get away with parts from OReilleys or Napa or Advanced Auto if I pick a better, more expensive options? Is that place: 1st Subaru the best place to order factory Subaru parts? Thanks a ton!
#2 |
Member#: 295857
Not having the best luck finding factory parts for the timing belt.
I think I'll go with a kit from either DAYCO, ACDELCO, GATES or GOODYEAR. Anyone have experience/knowledge of those brands? I'm leaning towards ACDELCO... Thanks |
#3 |
Member#: 273859
W. Canada
Vehicle:MY98 WRX |
Get the GATES kit. very commonly used.
#4 | |
Member#: 312107
NESIC
Vehicle:1998 LowFoz Glacier White |
#5 |
Member#: 253560
South East
Vehicle:03 VW Golf Slow |
+1 for Gates
#6 |
Member#: 96866
I used the gates kit this past week, every pulley that came with the kit was the same as the ones coming out of the car. The gates belt is NOT made in Japan like the box says, it's made in the USA. The only thing I bought from Subaru was the water pump.
#7 |
Member#: 294461
NWIC
Vehicle:1997 Outback Sport Acadia Green Metallic |
Mitsuboshi timing belt, Cometic head gaskets, GMB water pump... I buy from Mizumo Auto on eBay and get the Mitsuboshi/GMB kit plus the cam seals and pulleys it comes with. Brilliant kit.
#8 |
Member#: 314221
I am new to Subaru and was going to replace my daughters timing belt on her 97 Impreza 2.2l EJ22. I was going with a gates kit with water pump and was looking to replace the cam seals as well. I was looking for any advice in removing the cam sprockets and to ask is there anything else I should do while in there. Any advice would be appreciated.
#9 |
Member#: 58906
gates blue belts. they are higher quality from normal gates belts.
they also make blue hoses and accessory belts. only on certain applications. http://www.gatesracing.com/ |
#10 |
Member#: 327502
Vehicle:2007 Impreza 2.5i Blue |
what about dayco from advance? i have never heard anyone having any problems with them?
#11 |
Member#: 96866
Gates for the timing belt kit and valve cover gaskets, Subaru for waterpump, sti 642 head gasket, intake and exhaust gaskets
#12 |
Member#: 170186
Vehicle:03 PTGT Blue |
does the water pump that comes with the gates kit, have the higher flow impeller design? or the open fin design?
#13 |
Member#: 146216
South East
Vehicle:2007 Impreza 2.5i SE Newport Blue Metallic |
Gates or Subaru OEM for everything except the Headgaskets
For Headgaskets purchase Six Star Brand MLS Gaskets http://allwheeldriveauto.com/six-sta...d-gasket-kits/ |
#14 |
Member#: 337059
We use either gates or dayco tbelt kits.
#15 |
Member#: 273906
NESIC
Vehicle:1831 Conestoga Wagon My oxen all died. |
If you're going to use Fel-pro head gaskets, you might want to try the PermatorqueMLS. They're around $60/pair at Rockauto.com, so half as cheap as the Six Stars. The part number I used for my '03 SOHC outback is 26415 PT, which is 0.026" thick. 26167 PT is the thicker gasket (0.053") and is the part number for the DOHC engine in which the pistons extend past the deck. Measure your head gaskets with calipers if you're not sure which one to buy. They seem very well made to me, and are doing well so far. They aren't as popular as the Six Stars, but if you want to save $60 (as I did), then I think it's worth it. Plus, they're a pretty blue color!!!
#16 |
Visiting NASIOC Timeout
Member#: 70710
Vehicle:2002 04STi Swaped RS w/PPGS & 02 Wagon w/PPGs |
I usually get my timing kits off ebay, with out a belt and then get a good Gates belt were ever....often ebay again if the price is right.
#17 |
Member#: 273906
NESIC
#18 |
Member#: 70710
I only snatch up the sets that are a better deal then normal. Its not a scenario of Oh I need a timing kit to ebay we go, its Oh WoW thats a freaking good deal I'll buy that for the next time I need it for a build or one of my cars.
#19 |
Member#: 147102
Just installed a Gates kit from Amazon. Belt made in USA. All other parts including bearings Made in Japan. Very good quality.
#20 |
Member#: 338593
Vehicle:1999 Legacy Outback White |
I used the gates kit and the only real complaint I had was the water pump. It was advertised as OE, but it was not. I complained to Gates and found out that it was made in China and that the only parts that are guaranteed to be OE in their kits are the idlers. I'm thinking the USA belt was not OE, but I could be wrong. Their packaging needs to be improved as the idlers banged around into one another and I wound up needing to sand the idler to be comfortable installing it.
#21 |
Member#: 327502
anyone else have issues with the gates water pump?
#22 |
Member#: 315840
Vehicle:2000 2.5rs |
^ Would like to hear feedback from more Gates owners as well. Just bought one for my upcoming build. I've heard that you shouldn't use the water pump (from my tuner), and was going to go with the OEM unit.
#23 |
Member#: 327502
i decided to go with the if its not broke dont fix it approach with the water pump since mines not leaking im not touching it. i know i will have it leak afterwards if i change it.
#24 | |
Member#: 283881
Vehicle:2004 WRX wagon 2.0 Silver |
I am about to ask the same question of pistons and rings $150 really?? I don't want to throw away money and rebuild later anyway, but I am going back to stock? Any feedback?? |
