Old 08-03-2012, 09:45 PM   #1
Jutboy
Member#: 114371
Question P440 CEL - What do I do?
Emission System Control Error. Not sure how to even approach this....I looked around for any hoses with leaks. Checked the gas tank filler to make sure it didn't have any holes....everything seems fine.
Any ideas? I would greatly appreciate it.
-J
97 Impreza OB - Auto 2.2
Jutboy is offline   Reply With Quote
Old 08-09-2012, 08:46 PM   #2
Jimdew
Member#: 328640
My expereince......
My filler neck was rusted to hell. I replaced it, but from a different year legacy, and had some trouble figuring out what to do with the two extra vent hoses I suddenly had no home for. I ended up looping them together and my code went away and I could fill my tank without the pump shutting down.
There could be pinholes in your filler neck, or the vent lines from the tank. Us in the north have problems with filler necks rotting out from road salt, and the fact the plastic protector holds all the crud and salt against the filler neck.
Mine was so bad, the valve that was supposed to be on the filler neck that the two vent lines connected to was GONE!!!!
Other years are slightly different.
Mine is a 98 legacy wagon 2.2L 4eat
Jimdew is offline   Reply With Quote
Old 08-09-2012, 08:58 PM   #3
cal_look_zero
Member#: 294461
2006 San Remo Wagon
Under construction
cal_look_zero is offline   Reply With Quote
Old 08-10-2012, 01:27 AM   #4
bugeyetex
Member#: 283815
2003 psm wrx wagon
Built Fuji Tough
Originally Posted by Jimdew View Post
My expereince......
This reminded me of a time when I was filling up at the gas station only to look down and notice i was in the middle of a steadily growing puddle of gasoline... this one was a cracked neck on the tank.
bugeyetex is offline   Reply With Quote
Old 06-10-2013, 01:49 PM   #5
Volks826
Member#: 359062
i have the same problem, i have a 2004 impreza that i just bought two days ago. its throwing a evap code, the inside of my car smells like gasoline,im getting horrible gas mileage and my idling is off it either idles at 700 to 800 rpms or goes up to 2000 rpms, the guy i bought it from replaced the fuel pump and gas cap. any ideas?
Volks826 is offline   Reply With Quote
Old 06-10-2013, 04:51 PM   #6
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
There is a rather complex evap system on that car with at least one electrical solenoid and other plumbing. Plenty of places to have problems. Most of It is located under the trunk floor on the passenger side if you want to take a look for any obvious signs of damage or disconnected hoses. Most of it is visible by just sliding under the rear bumper.
Old 06-10-2013, 09:06 PM   #7
Volks826
Member#: 359062
Well the guy who i bought it from said that the code was on before he even did the fuel pump...
Old 06-10-2013, 09:48 PM   #8
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
That doesn't rule out anything except the fuel cap and pump (assuming they were both good replacements) Since they are new replacements
