#1 |
Member#: 305565
Vehicle:2001 rs impreza black |
Rebuilt 2001 2.5 after a timing belt mishap and a month later it starts smoking real bad. Did compression test, all cylinders at 200 psi, took heads and had new seals put in, Now with the piston and cylinder walls slightly exposed, how can you tell if rings need replaced? If at all.
#2 |
Member#: 317237
I don't think you can without removing the pistons. Maybe your valve seals are bad and dumping oil in the cylinder?
#3 |
Member#: 80465
RMIC
Vehicle:2001 2.5RS Black Diamond Pearl |
Leakdown test will tell you more. Do it.
...mishap? |
