#1 |
Member#: 17845
Vehicle:2002 WRX WRB |
I just wanted to get some information about how the ecu stores the boost and if it can be cleared. also, does it store it for each gear? Say I don't go above the stock boost but I set it so that I go to that boost in ALL gears. would subaru ever know? thanks for the help
#2 |
Member#: 3792
Vehicle:2002 6MT almost GDB |
Resetting the ECU clears it out. As far as the ECU remembering boost settings...no way! The ECU does not data log.
#3 |
Member#: 17845
so how can subaru tell what boost the car has been run at?
#4 |
Member#: 7764
Vehicle:11 Edge Sport Kona Blue Metallic |
When you set your check engine light off it stores a freeze frame of conditions at that instant. Among the items stored is boost at that time. That is the only way that the ECU can store boost level....
| Thread Tools | |
| Display Modes | |
| How does the ecu determine what gear you are in? | Bad Noodle | Open Source Reflashes | 3 | 10-07-2008 11:04 PM |
| Does the ECU pick real boost numbers | teamsubaru2006 | Newbies & FAQs | 2 | 10-11-2007 03:19 PM |
| The ecu that doesn't exist just arrived in the mail | 2slofouru | Subaru Conversions | 4 | 10-17-2006 10:03 AM |
| explain how with a mbc the ecu can pull boost back | suprasingle | Factory 2.0L Turbo Powertrain | 6 | 09-13-2002 08:22 PM |
| Does it needed to reset the ECU for the following changes? | V6 | Normally Aspirated Powertrain | 5 | 10-27-2000 09:32 AM |
