Old 08-04-2012, 08:24 PM   #1
cowboy_Rob
Member#: 194062
2003 Impreza WRX
Default Logging/reading/flashing question
03 wrx using an openport 2.0e I can have ecuflash and romraider editor and logger. It works to data log but I can seem to get it to pull the rom from the ecu so I can edit it. Originally thought it was because its a ecutek ecu so I bought another ecu and plugged that in and it still does the same thing. Cmd start 5 times then interface close. The green connectors are plugged in and it goes into test mode and cycles fans and all that. I've been reading faqs and forums and fighting with this thing for the past 2 1/2 hours. Uninstalled and reinstalled ecuflash and all
cowboy_Rob is offline   Reply With Quote
Old 08-04-2012, 10:08 PM   #2
quazimoto
Member#: 70395
Do you have the flash block installed? You have to turn the key to on and simutaniously hit "ok" to flash. If the car is going into test mode your to late. My 02 never goes into test when when I flash.
quazimoto is offline   Reply With Quote
Old 08-04-2012, 10:41 PM   #3
cowboy_Rob
Member#: 194062
2003 Impreza WRX
Yea I was reading the FAQ and missing the part at the bottom that said 16bit ecus need the flash block. I coulda swore when we did my buddies car the flash block was just for flashing Roma not reading em but I guess not.
Now I just gotta figure out why the maf scaling tool isn't populating any red dots. So much fun trying to start a tune from scratch on a already modded car cuz the old ecu is ecutek locked
