Old 08-20-2013, 12:57 PM   #101
puffywill
Member#: 305759
2010 STi
Originally Posted by AnthonyA182 View Post
Has anyone verified a way to solve the charging issue? N7's are cheap enough that I'd be willing to leave one in the dash permanently provided it could stay charged indefinitely.
Nice install OP
I dont know if the nexus will be able to handle the texas heat in the summer
my plan is to put a wireless charging pad in the back and make the nexus removable
puffywill is offline   Reply With Quote
Old 08-27-2013, 03:00 AM   #102
suspect_device
Member#: 366415
Nice install OP
Walmart sells a fast charging 2.1 amp auxillary plug that will charge the N7. Costs maybe $10. 2 USB ports and 1 auxillary plug. The USB ports are a maximum of 3 amps total, so if you plug two devices in, they are getting 1.5 amps apiece.
suspect_device is offline   Reply With Quote
Old 08-27-2013, 11:46 AM   #103
PiNPOiNT
Member#: 131121
I installed one of these into my ignition switch.
DC-Converter-Buck-Module-12V-convert-to-5V-USB-output-power-adapter
http://www.ebay.com/itm/DC-Converter...3832?viewitem=
Its 3A USB DC , so you can plug the nexus directly into it and power it off that.
If you are using Timurs USB rom (with and OTG cable), it will automatically turn the nexus on with it receives power and then into a deep sleep when you power off the unit. It will only loose 3%-4% of its battery each 24 hours, but you will quickly recharge that after a short drive.
PiNPOiNT is offline   Reply With Quote
