Old 08-05-2012, 11:14 AM   #1
spoolya05
Member#: 308104
2005 STI
Aspen white
Default Need help, crankshaft sensor problem
I have a 05 STI and my car will run and drive fine then all the sudden it will start to skip and sputter and my tack will start to jump around it will back fire real bad and then cut off. Once it cuts off it will not crank up again. It will throw a code for crankshaft position sensor. I've changed the sensor and it would crank right up and drive fine again for a little then do it all over again. I put the original sensor back in and it would crank right back up. This morning I got in and it wouldn't crank so I just unplugged the sensor then back in and no problems, for now anyway. I need help I'm lost. The plug is fine also. Thanks
spoolya05 is offline   Reply With Quote
Old 08-05-2012, 11:27 AM   #2
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Sounds like wiring, not the sensor, did the wire ever get pulled?
Old 08-05-2012, 11:39 AM   #3
spoolya05
Member#: 308104
2005 STI
Aspen white
Well Topspeed just put a new motor in my car, when I talked to them they said it was the sensor but they did say they unclipped the prongs from the clip but I looked at it and it looks fine and there not loose
Old 08-05-2012, 02:48 PM   #4
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
It would help us to know what the code was you saw. There may be a engine grounding problem causing the trouble possibly.
Old 08-05-2012, 03:32 PM   #5
spoolya05
Member#: 308104
2005 STI
Aspen white
The code was for crankshaft position sensor. There was a loose ground wire and that got fixed but it still did it. Today I've been driving it and it's not doing it now, I had that one problem this morning but nothing since then. It's really weird. I can just feel like I'm gonna be driving down the street and it breaks down on me again.
Old 08-14-2012, 09:47 PM   #6
daneg6
Member#: 189594
2005 WRX STi
WR blue
i had the same issue on my car a while ago. to this day i dont know what exactly fixed it i gave up took it to the dealer. They couldnt find the source pulled half the car apart put it back together and then said it was the chip in my key. Replaced the key and havent had that issue since. If you ever find the cause let me know just for some piece of mind.
daneg6 is offline   Reply With Quote
Old 08-18-2012, 07:13 PM   #7
spoolya05
Member#: 308104
2005 STI
Aspen white
Well it's been about two weeks now and I havnt had another problem since my last post that morning. Idk what it was but it's not doing it now so I'm happy. If I find out I'll let you know.
