Old 08-05-2012, 11:27 AM   #1
TravisL
Member#: 288101
Default Car crawls when put into gear(auto)
I've found another subie I'm thinking about looking at as a repair project, I'm just looking for other peoples opinions or guesses at this point. It's an 03' legacy 2.5L auto. The owner says it starts and runs, but when put into gear it'll only crawl, more throttle does not result in more movement.
Is this likely a bad transmission or something else? I've never had a transmission present a symptom like that but I could see it being possible? It's got about 120k miles on it also.
Thanks for any tips guys, and I apologize if I'm in the wrong forum.....not knowing what the issue really is I stuck it here.
TravisL is offline   Reply With Quote
Old 08-05-2012, 11:55 AM   #2
fmars62
Member#: 290517
2008 Impreza 2.5i
Dark Grey Metallic
i thought whenever you put any automatic into gear it starts crawling?
fmars62 is offline   Reply With Quote
Old 08-05-2012, 12:00 PM   #3
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
Could be as simple as a stuck brake.
Old 08-05-2012, 01:06 PM   #4
TravisL
Member#: 288101
Yes, but this only crawls lol, no matter how much you push on the gas pedal.
Old 08-05-2012, 02:44 PM   #5
scoobymatt93
Member#: 254115
2009 Impreza 2.5i
Dark Grey Metallic
When you press on the gas, does the engine still increase in RPM and whatnot, but it just stays on crawling?
scoobymatt93 is offline   Reply With Quote
Old 08-05-2012, 03:39 PM   #6
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
That's funny
As the previous poster wrote, does the RPM change when you floor it in D? Also, what happends in N and R when you push on the gas pedal? It'll help pinpointing the issue.
Old 08-05-2012, 08:22 PM   #7
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
also, chk the fluid. if its low or mostly empty, the tq converter cannot do its job well.
Old 08-05-2012, 09:40 PM   #8
fmars62
Member#: 290517
2008 Impreza 2.5i
Dark Grey Metallic
oh, lol, idk then...haha. good luck with the fix!
Old 08-06-2012, 08:18 AM   #9
sharpie622
Member#: 268035
2007 Impreza 2.5i
I had the same thing happen to my 07 2.5i and it turned out that one of the drive axles popped out of the transmission. You can check the front two directly from the engine bay.
sharpie622 is offline   Reply With Quote
