Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Old 08-05-2012, 08:04 PM   #1
tmcgraw
Member#: 287023
2016 BMW M4
Default 2011 WRX stage 2 log review
Can someone please look at these logs and let me know what you think? I just flashed to stage 2 today with an invidia catted down pipe. Thanks in advance.
https://docs.google.com/spreadsheet/...VdyZ3Rzb0IzSXc
https://docs.google.com/spreadsheet/...W5CRU9FYnUtaEE
tmcgraw is offline   Reply With Quote
Old 08-06-2012, 01:58 AM   #2
bacalhau16
Member#: 297565
2011 WRX hatch
Cobb is usually really good about checking these in the morning. The only thing I see is he differences in AF learning between the 2 maps and it being a negative value. Im not even sure if that means anything, hopefully Bill can help me out with that. Everything else looks great.
bacalhau16 is offline   Reply With Quote
Old 08-06-2012, 09:31 AM   #3
Cobb Tuning
Member#: 4803
I would reset your log list to the default on the AccessPORT (via Monitor -> Reset Log List). You have added "A/F Learning 1 A" and removed "A/F Learning 1", which will only show us the A version of your long-term fuel trims and not the rest. "A/F Learning 1" will show us the currently applied long-term fuel trim (of the 4 available). Also, TD Boost Error has been removed which is useful to determine if you are hitting the actual final boost target that the ECU has determined.
I would get some more logs with the log list reset, but based on what have here, it looks good, except if you are running the 91 octane map, boost may be a little high. The A/F Learning 1 A in the second log is a borderline extreme - would be good to see what the rest of the trims are at (B, C, D).
Bill
