Welcome to the North American Subaru Impreza Owners Club Sunday April 19, 2015
Old 11-19-2012, 11:44 AM   #251
11sti_v8bait
Member#: 338295
Nice car dude I'm jealous
11sti_v8bait is offline   Reply With Quote
Old 11-20-2012, 08:34 AM   #252
baseballdbk1
Member#: 242700
2011 Impreza Wrx Sti
Thank you!
baseballdbk1 is offline   Reply With Quote
Old 11-20-2012, 12:25 PM   #253
slowgenius
Member#: 48350
0304 0712 WRX/Sti
Looks great man!
slowgenius is offline   Reply With Quote
Old 11-20-2012, 03:15 PM   #254
baseballdbk1
Member#: 242700
Originally Posted by slowgenius
Looks great man!
Thanks a lot, much appreciated!
Old 11-20-2012, 03:20 PM   #255
baseballdbk1
Member#: 242700
Custom surgetank trunk support and catch can/fuel pressure regulator bracket being fabricated tomorrow!
expect a big "fuel system" update in the near future, followed by dyno numbers! :-)
Old 11-20-2012, 04:39 PM   #256
slowgenius
Member#: 48350
0304 0712 WRX/Sti
Who is fabricating up your stuff? I may need to have some done for my build.
Old 11-20-2012, 05:06 PM   #257
baseballdbk1
Member#: 242700
TPG is taking care of everything!
Old 11-20-2012, 05:12 PM   #258
slowgenius
Member#: 48350
0304 0712 WRX/Sti
Ok cool ill see nate at the meet
Old 11-20-2012, 09:45 PM   #259
Irv Weissmanhowerton
Member#: 278519
30r E85 STI 450+whp
kb'izzle
Has anyone heard of needing to break down dual valve springs to 1 when using kelford 199-c (272) for break in??
along with the low 15-2k idle for 15-20 min or whatever it says
Im using some used supertech dual valve springs/ti retainers (70 spring rate) with my new build, and was wondering how important this was/ how necessary with using 1 of the 2 springs for break in, then putting the 2nd spring back on after break in.
edit, nvm, found this article that says yes: ttp://www.camshaftshop.com/kelford-cams-flat-tappet-camshaft-breakin-procedure.php
and this that rec. their single spring http://www.camshaftshop.com/products.php?productid=1035
Irv Weissmanhowerton is offline   Reply With Quote
Old 11-21-2012, 06:59 PM   #260
baseballdbk1
Member#: 242700
Fuel Update:
Started pulling out the factory fuel lines and before you know it, everything was ripped out and ready to put the new setup in place!
Replacement Components:
Russell "Pro Classic" fuel lines(-8 feed and -6 return)
Fuelab "Prodigy Series" 41401-c in-line fuel pump
Fuelab in-line fuel filters w/ stainless steel filters
Aluminium surge tank
With all of these components in place, we will finally be able to push the engine to 28psi while maintaining safe AFRs on E85 which requires around 30% more than using 93 octane pump gas so the stock fuel system can not handle what we are trying to accomplish!
Here are a few pictures of the fuel lines and Fuelab in-line pump "power wire" from the engine bay back to the trunk where the fuel lines are are gonna ran to the surge tank and new lines are also being ran from the in-tank pump assembly to the surge tank!
Old 11-21-2012, 10:34 PM   #261
TPG Tuning
Member#: 185725
This is fairly common with domestic style pushrod engines but its my that practical for a OHC engine, especially a Subaru. Also, compared to some of the big dual and triple springs used in the domestic world our stuff isant that crazy, even the big Ferrea springs we use. It wouldn't be a 30min job on an EJ head like it would on an SBC!
Nate
TPG
TPG Tuning is offline   Reply With Quote
Old 11-22-2012, 12:04 AM   #262
john 1badSTI
Member#: 77470
04 sti 10.51@138.5
on e85@ 30psi--spinning
hey baseball I hate to point this out but in my opinion it is not really safe or wise to run your fuel lines inside the pass. compartment under the carpet and that close to your electrical wires for your pump.You are just asking for trouble and if something bad does happen your car is going to burn to the ground really quickly.BTW it would be different if your lines were done in hard stainless.
john 1badSTI is offline   Reply With Quote
Old 11-22-2012, 12:49 AM   #263
baseballdbk1
Member#: 242700
I understand your reasoning of it being unsafe but with the fuel lines being properly secured and insulated, just like the power wire I see no major worries...
The lines are also not in direct contact anywhere in the cabin for safety reasons.
The new lines are ran in the same exact placement as the stock lines under hard plastic casing and the power wire is ran above the plastic to avoid any concerns.
The closest the 2 come to contact is in the rear of the vehicle where I will be covering the fuel lines with an additional shielding material!
I have been dealing with automotive electrical systems for a good amount of time and would cut corners for ease of installation if it sacrifices safety
Old 11-22-2012, 01:08 AM   #264
bettner12
Member#: 56179
05 LGT 407hp/372tq
Tuned by mike@innovative
Scca rules mandate any fluid lines inside the passenger compartment must be of stainless steel construction. We cut about 25lbs off of the trans-am car, but one place we couldn't use starlite kevlar/nomex was the passenger compartment. Not saying either way which is better, just informing you what racing organizations say in case you ever want to get into more than just drag strip
bettner12 is offline   Reply With Quote
Old 11-22-2012, 01:02 PM   #265
TPG Tuning
Member#: 185725
Does that mean you can't run a 08+ WRX/ STi in SCCA? The stock lines run inside the car!
Old 11-22-2012, 01:13 PM   #266
baseballdbk1
Member#: 242700
Haha I was thinking the same thing...
It's funny they would even have that rule when the fastest you go in autocross is probably what? Around 50mph?
But I can go to the drag strip and run 130+mph with no questions asked? lol
Old 11-22-2012, 02:42 PM   #267
JSti07
Member#: 190019
07 STi
swp
I say we go to the track next year!
JSti07 is online now   Reply With Quote
Old 11-22-2012, 02:43 PM   #268
TPG Tuning
Member#: 185725
Yes!
Dave's car traps 140 yours traps 125 or bust!
Nate
TPG
Old 11-22-2012, 02:47 PM   #269
JSti07
Member#: 190019
07 STi
swp
I have never taken my car to the drag strip, I will have to try it out one day
Old 11-22-2012, 03:37 PM   #270
MRF582
Member#: 48219
. Always drive
the race line .
By the 'track' you guys mean the 'strip' right? Because, imo, a 'track' generally has left and right turns and you sometimes have to decelerate and downshift.
I know that's a foreign concept to you guys but still, BeaveRun (or Pitt Race Complex) is right in our backyards. Hell, even Nelson Ledges RC is just over an hour away. I'd love to see what kind of lap times some of these super fast Suby's run.
MRF582 is offline   Reply With Quote
Old 11-22-2012, 04:46 PM   #271
TPG Tuning
Member#: 185725
I think my reference to a drag strip was pretty apparent with the trap speed goals.
This is America, everyone has the right to there own opinions! I was brought up a drag racer and always will be, to each there own. I've been to SCCA courses that you don't even break the speed limit, that ain't racing lol. I wouldn't mind getting my GTR on a big road course though.
Happy Thanksgiving Everyone!
Nate
TPG
Old 11-22-2012, 11:31 PM   #272
JSti07
Member#: 190019
07 STi
swp
No I ment track, not as in drag strip. I just think Nate took it differently. I'm actually planning to make some trips to a couple of those tracks next year, need to learn more and improve my driving skills
I agree with you Nate, autocross isn't the greatest but around here it's all I have unfortunately. I am really excited to get out on some road courses though.
I would be willing to try out the drag strip one day, if not I'd go just to watch Dave.
Old 11-24-2012, 12:35 AM   #273
Bang876
Member#: 308854
2005 WRX STi
World Rally Blue
Beautiful car and set up man. I have a GT35R on my set up but never got the balls to really tune her up. But after seeing your video and how much fun you seem to have building it, I'm going to give my a little push. Thanks for sharing.
Bang876 is offline   Reply With Quote
Old 11-24-2012, 01:32 PM   #274
MRF582
Member#: 48219
. Always drive
the race line .
Track != AutoX
Track != Drag Strip
Track = Road Course
Let me know when you go to BeaveRun or Nelson Ledges next. I'd like to hook up my datalogger.
Old 11-24-2012, 01:34 PM   #275
Darcros
Member#: 196496
2006 STI
Originally Posted by baseballdbk1 View Post
Here is the new fuel system we are installing:
So nice that someone does a fuel system the correct way..
Darcros is offline   Reply With Quote
