Old 04-10-2013, 10:37 PM   #351
MRF582
Member#: 48219
. Always drive
the race line .
Originally Posted by baseballdbk1 View Post
Im going to post graphs from the mustang dyno at TPG Tuning that the car is being tuned on, as well virtual dyno graphs for both mustang and dynojet for a comparison between the three!
Awesome! AFAIK, data like this hasn't been captured, for any setup.
MRF582 is offline   Reply With Quote
Old 04-10-2013, 10:44 PM   #352
baseballdbk1
Member#: 242700
2015 Impreza Wrx
Well then... Maybe I will try and put it on an actual dynojet as well for more info!
baseballdbk1 is offline   Reply With Quote
Old 04-11-2013, 08:12 AM   #353
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Thats awesome, thanks for taking the time to do a great comparison .
So far the only other two subaru 6266 setups have made 580whp and 590whp on VD dynojet on E85. Your car has way more mods than the other ones
Old 04-11-2013, 09:56 AM   #354
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
No problem and thanks a lot!
FujiK did a Dynojet vs. Mustang vs. Airboy
http://forums.nasioc.com/forums/show....php?t=2041890
I did a Dynojet vs. Virtual Dyno
http://forums.nasioc.com/forums/show....php?t=2389720
For Virtual Dyno Mustang vs. Virtual Dyno Dynojet, there is no comparison needed. It's a 14% difference. That is simply built into the correction factor of the software.
Getting it onto a real Dynojet could be interesting but you already showed that it's a ~7% difference with your other plots.
I think I'm most interested in the VD plots or even some speedo video's of 3rd and 4th gear pulls. That seems like the easiest to compare. Especially the pull video's. That really shows how quick it actually is.
FYI - My 6266 setup makes about 575WHP at 29-30psi and around 600WHP at 30-31psi (on Virtual Dyno - Dynojet). I am on winter blend E85, but I am also on stock cams. Based on your Mustang dyno results I would guess you'll do low to mid 600's on Virtual Dyno - Dynojet.
xluben is offline   Reply With Quote
Old 04-11-2013, 10:09 AM   #355
MRF582
Member#: 48219
. Always drive
the race line .
^Good post. Thanks, didn't know.
Old 04-16-2013, 02:17 AM   #356
baseballdbk1
Member#: 242700
2015 Impreza Wrx
I don't know what parts the other ones have installed but I know the only other thing to make more power that I can think of would be to sleeve the block(should have done it while the engine was apart ) but I will most likely do that during next winter!
Since the last it was on the dyno and made 574/591 on E70, I have added the Boomba Racing 75mm TB, Full Race "stock location" exhaust manifold, switched to the Invidia single exit "race" catback over the Q300 and now using E90 instead E70, I really have no idea what to expect when we tune it today! I guess we will see this afternoon around 3
Old 04-16-2013, 08:16 AM   #357
juanmedina
Member#: 133146
Awesome! good luck today. I can't wait to see the results
Old 04-17-2013, 10:39 PM   #358
juanmedina
Member#: 133146
update?
Old 04-17-2013, 10:40 PM   #359
Januch09
Member#: 309459
2011 STi Sedan
Satin White Perl
Also interested in some numbers? Very excited about this build!
Januch09 is offline   Reply With Quote
Old 04-17-2013, 11:08 PM   #360
baseballdbk1
Member#: 242700
2015 Impreza Wrx
Haha Well there are no numbers for the time being due to the fact we are now making changes to the trunk moumted fuel system!
My second Fuelab 40401 external fuel pump has died so we are making changes for the better ;-)
I just ordered a Radium engineering Dual Bosch 044 fuel surge tank w/ -8 feed line that is posted in the picture below!
There is already a plan in place for wiring, mounting, etc and should come out amazing because it will give the sti even more of the "street car" feel that I am aiming for due to quieter cabin, more reliability and less trunk space required for mounting compared to my previous setup!
Old 04-17-2013, 11:13 PM   #361
Januch09
Member#: 309459
2011 STi Sedan
Satin White Perl
I actually came a cross a thread where a guy with an 11 hatch ran a similar fuel setup for E85. It worked very well for him! Good luck! And I know the feeling of wanting it to be done and make numbers and then more problems occur, more mods needed...It sucks but it's all apart of the build process. Keep us posted! Awesome build thread!
Old 04-17-2013, 11:30 PM   #362
baseballdbk1
Member#: 242700
2015 Impreza Wrx
Thank you very much and that's awesome to hear there is someone else using the same setup with good results!
Yea it sucks we have to push off dynoing it for the time being but I think it's for the better performance and visual wise!
I'll be sure to keep the updates coming as we make progress with the install!
Old 04-17-2013, 11:45 PM   #363
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
I like the looks of this. Clean.
Does it fit in the spare tire well nice?
TDagen is offline   Reply With Quote
Old 04-17-2013, 11:57 PM   #364
famemush
Member#: 332696
Looks and sounds awesome
famemush is offline   Reply With Quote
Old 04-18-2013, 12:02 AM   #365
baseballdbk1
Member#: 242700
2015 Impreza Wrx
Thanks!
Haha well are options are either mount the fuel system in the spare tire area or mount in the back left corner(retain spare tire) of the trunk area!
I would not mind it in either spot so I'll worry about that when the time comes to install!
Old 04-18-2013, 09:47 AM   #366
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
So you had two external fuelab pumps die on you? Is there more to the story, and about how you ran it? I am curious because i have a fuelab external pump going on my fuel system.
slowgenius is offline   Reply With Quote
Old 04-18-2013, 01:02 PM   #367
baseballdbk1
Member#: 242700
2015 Impreza Wrx
Not really anything more to say other than they died unfortunately...
Ran it on low speed at all times, pre and post filter, proper wiring setup, etc
Old 04-18-2013, 02:26 PM   #368
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
Oh ok. Did they warranty them? Did they give an explanation, or apology? This really concerns me because its almost a 500 dollar pump feeding a 10k dollar motor.
Old 04-18-2013, 02:51 PM   #369
baseballdbk1
Member#: 242700
2015 Impreza Wrx
I called them about this most recent pump that failed and they just told me to send it in for testing and then go from there...
I swear there is something goofy with the speed control circuit is those pumps!
fuel pressure would randomly fluctuate between 50 PSI(bass pressure) and 20 PSI at idle, as well as the sound of the pump would change greatly!
Old 04-18-2013, 03:12 PM   #370
SpongeBobSquarePants
Member#: 296048
2011 STI
Blurple
Just curious if you plan on bringing this car to Englishtown?
I'd like too be there that day
SpongeBobSquarePants is offline   Reply With Quote
Old 04-18-2013, 03:14 PM   #371
baseballdbk1
Member#: 242700
2015 Impreza Wrx
For which event?
I'm always down for a road trip!
Old 04-18-2013, 03:27 PM   #372
Member#: 296048
2011 STI
Blurple
I meant in general. This is my home track and if love to see this car in person.
Old 04-18-2013, 03:56 PM   #373
baseballdbk1
Member#: 242700
2015 Impreza Wrx
Oh I got ya!
Yea that is a lil bit of a drive just to go but if they do a sti vs evo event or something like that I would love to go!
I dont know if you plan on going, but im gonna be taking it down to the OC AWD Meet in june
Old 04-18-2013, 04:07 PM   #374
phillcam021
Member#: 260937
2005 wrx sti
Should bring her down for kc2k13 may 18-19 !!!
phillcam021 is offline   Reply With Quote
Old 04-18-2013, 07:22 PM   #375
baseballdbk1
Member#: 242700
2015 Impreza Wrx
I wish it was that easy to go to every event this summer lol
I have a good idea of the list of events I want to bring the car to and we'll see how many of those I even make it to
