Old 08-05-2012, 10:28 PM   #1
robbyh
Member#: 326959
2004 wrx
black
Default New guy here
Hey everyone,
Well I recently got me an 04 wrx (traded my street bike for it). The car has 113k miles, and according to carfax it's had more then a few owners (i'm #9). So for that reason I'm gonna be giving the car a good tune up and conditioning.
Plans are to do the following:
Oil & filter
Trans fluid
Rear diff fluid
Break fluid
Coolant flush
Timing belt & tensioners & water pump
Spark plugs
Acc belts
Also may drop the center diff and replace the bearings just cause I "think" I heard a whine when I drove it home. That or it could of been from the crappy bald tires which are also out of alignment.
So yeah that's my plans. If there is anything else I should change or check feel free to provide input.
robbyh is offline   Reply With Quote
Old 09-01-2012, 12:54 AM   #2
robbyh
Member#: 326959
2004 wrx
black
Well I've had the car now almost a month. Most of that month its been sitting on jack stands waiting for parts to arrive. The only down side is the more I take off the more parts I want to buy and install because I'm already there lol.
Starting point - Engine is all stock
First change, removing any curb rash and and then powder coating the wheels. They are a metalic copper blend but my camera phone didnt capature it very well.
next week comes i should get in the remaiing parts, install tires and get an alignment. Then I'm not sure maybe a AP
Replacing front passenger axle, still waiting on new axle to arrive
new adjustible rear control arms
turbo looks decent for 113k miles
A lot of work to get this out but worth it.
Old 09-01-2012, 01:14 AM   #3
FraudulentNeon
Member#: 29108
2002 Impreza WRX
Congrats! Throw those tail light tints into a volcano, just to be sure!
FraudulentNeon is offline   Reply With Quote
Old 09-01-2012, 01:49 AM   #4
robbyh
Member#: 326959
2004 wrx
black
lol yeah they are on the list to be replaced as well.
Old 09-04-2012, 11:06 PM   #5
jakeyp_fxt
Member#: 292256
2005 FXT 5MT
Throw some pics up of your car with the new wheels!
And add replacing the cabin air filter to the list. It's located behind the glovebox and only takes a few minutes to get out. And they are fairly inexpensive (compared to what the stealership will charge you). I picked up mine for about $15 from amazon.
jakeyp_fxt is offline   Reply With Quote
Old 09-05-2012, 07:11 AM   #6
robbyh
Member#: 326959
2004 wrx
black
Will do. Planning on getting tires installed tomorrow before work.
Yeah I will do the cabin filter as well. Already did engine filter.
Debating on doing plugs. I got them already but looks like a little pain to install.
Old 09-07-2012, 05:01 PM   #7
robbyh
Member#: 326959
2004 wrx
black
Installed Perrin heat shield with DEI gold heat tape on the underside (idk if it will make a difference but it might)
And finally got around to putting the tires on and getting an alignment
But the "tech" didnt seam to try to hard to get it right so I'll have to take it back another day after my camber bolts arrive.
Currently front L(0.5) R(0.2), Rear (L0.0) R(-0.3)
Old 09-07-2012, 09:54 PM   #8
mhoerath
Member#: 131379
2003 354 [email protected] rpm
justablue hatch
some inexpensive mods to do...
i put ngk iridiums in and they last awhile and reflecta golded my heat shield around the tmic and y pipe underneath (hint mods are endless).
bushings are a cheap mod, especially if install yourself. like you i replaced my lat links with adjustable that came with bushings already. trailing arm and rear diff and subframe bushings are huge. i just replaced my front lca bushings, 2nd time around.
if you can bump your idle up to 900-1k rpm do it. was advised oem 500 idle was just too low to cool and oil the engine. the oem plastic tanks on the radiator will eventually crack and i bought a fleabay cx r dual core radiator for like $150...replaced the cheap drain plug with a brass for $2 and reused my oem fans/shrouds. last suggest water wetter or mocool...and a grimmspeed 160 degree thermostat...keep engine cooler. like your rims.
mhoerath is offline   Reply With Quote
Old 09-08-2012, 05:46 PM   #9
datnguyen24
Member#: 320171
For being the 9th owner that Subaru looks clean. Keep us posted on the current mods and take lots of pictures.
datnguyen24 is offline   Reply With Quote
Old 09-08-2012, 07:59 PM   #10
kev29
Member#: 321425
2002 Impreza WRX
Nice looking car. You have started quickly.
kev29 is offline   Reply With Quote
Old 09-09-2012, 12:57 AM   #11
robbyh
Member#: 326959
2004 wrx
black
Yeah 2 or 3 core radiator is on the list for next spring since summer is almost over and all.
I'm trying to get it all set up but with so many previous owners it's been neglected pretty bad. The paint is nice but last owner went crazy with tint spray and the car has a bunch of over spray.
Also have a weird whine I have yet to diagnose. Thinking its either center diff bearings or a driveline issue. Only hear it at 60-80 mph. So gotta figure it out so I can fix it.
Old 09-09-2012, 12:19 PM   #12
flath4
Member#: 331643
nice wheels
flath4 is offline   Reply With Quote
Old 10-16-2012, 02:46 PM   #13
robbyh
Member#: 326959
2004 wrx
black
New part just arrived for install
Tmic should be here tomorrow and AP will be here in a few days so ill be busy with more upgrades.
Might have a vf39 and pinks in the near future. Depends on the deal.
Old 10-16-2012, 04:34 PM   #14
russ9127
Member#: 189531
2008 WRX Hatch
Silver w/ STi spoiler
It would looks sweet lowered slightly with those wheels! Nice progression!
russ9127 is offline   Reply With Quote
Old 10-16-2012, 05:48 PM   #15
robbyh
Member#: 326959
2004 wrx
black
Yeah it needs to be lowered. Someday here soon
Old 10-17-2012, 09:36 PM   #16
robbyh
Member#: 326959
2004 wrx
black
Installed downpipe today and then ups showed up with this so I had to install it too
Old 10-17-2012, 10:29 PM   #17
rob1n1
Member#: 276425
2013 335is
Alpine White
What TMIC is that?
rob1n1 is online now   Reply With Quote
Old 10-17-2012, 10:41 PM   #18
robbyh
Member#: 326959
2004 wrx
black
Ebay one that came with y pipe. Fit it pretty good. Doesn't hit ac lines. But elbow was a bit to long so I had to trim it.
Old 10-18-2012, 07:28 PM   #19
robbyh
Member#: 326959
2004 wrx
black
Just installed a walbro 255. Was super easy. Popped the old one out and new one slipped right in. Didnt take any pics cause I forgot. Lol
Old 10-18-2012, 08:37 PM   #20
KelConquer
Member#: 321498
1998 Legacy W. EJ25
Subscribed, good to see you're taking good care of it. Looking great already!
KelConquer is offline   Reply With Quote
Old 10-20-2012, 11:02 PM   #21
robbyh
Member#: 326959
2004 wrx
black
Fresh from the postman
Now to download a map and get it tuned up
Old 10-20-2012, 11:10 PM   #22
SloMo92
Member#: 335617
1992 Mustang LX
Bimini Blue
I'm jealous, wish I could find someone somewhat local willing to give up their WRX for my Harley. Nice looking car, and congrats to the nice build already under way.
SloMo92 is offline   Reply With Quote
Old 10-24-2012, 07:36 PM   #23
robbyh
Member#: 326959
2004 wrx
black
Thanks. Yeah it took awhike to find the right trade.
Old 10-24-2012, 07:48 PM   #24
robbyh
Member#: 326959
2004 wrx
black
Picked up a few more parts today
Gonna install them next week on my days off I think.
Vf39 with only 10k miles on it
Pinks with new seals
Old 10-24-2012, 11:43 PM   #25
raven32usk
Member#: 86599
2004 Impreza WRX
Java Black Pearl
Default nice 04
awesome dude! i have an 04 wrx myself with around 100k miles. nice to see another clean one. i am currently sitting at stage 2 - but i like what you are doing with yours. keep it up!
raven32usk is offline   Reply With Quote
