Old 10-30-2012, 02:11 AM   #26
robbyh
Member#: 326959
2004 wrx
black
Started on the sawp this evening
Only a few things that were a pia. Getting the inlet back on and the oil drain. It was easier to remove it from the bottom near the motor rather then next to the turbo. But putting the clamp back on sucked until I thought of using a zip tie to hold the clamp open. Then it was easy to slide it over the hose and then cut the zip tie to release it into place.
But got it all installed in about 2 hrs
Tomorrow ill do the injectors and tune. Hopefully
robbyh is offline   Reply With Quote
Old 11-02-2012, 07:08 AM   #27
robbyh
Member#: 326959
2004 wrx
black
Turbo and injectors are installed
Overall not difficult more of a pia.
Cobb ots map installed currently snd car is running good. But not really a noticeable hp increase over stage 2. Expecting to see better gains after protune.
Only qurstion now is do I get the tune or wait and do ebcs and inlet first then tune.
Old 11-17-2012, 12:40 AM   #28
robbyh
Member#: 326959
2004 wrx
black
Well today my HOA ebca arrived (thanks wtdash) and I got my stage 4 protune from Clark.
Only started it up and let it idle for tonight but fired up perfect and was as smooth as ever. Tomorrow I'll do some logging on my way to work and get any additional tweeks as needed from Clark.
Next I need to hit the dyno and see where I'm at.. Maybe after the 1st of the year.
Old 04-17-2013, 06:11 PM   #29
robbyh
Member#: 326959
2004 wrx
black
Well its been a few months sicne I stopped by this thread so I figuered I'd post.
Car is still runing strong on the ProTune, no codes no problems. Had planned to lower it and completely re-do the stereo and speakers but ended up spending the $ on a new camera lol.
04 wrx by robby, on Flickr
Old 05-22-2014, 02:06 PM   #30
robbyh
Member#: 326959
2004 wrx
black
Wow its been a year since I've updated this. guess time does fly when your not looking.
Well since the last update I still haven't lowered it or upgraded the stereo lol. Ended up doing more just maintenance items, brakes, rotors, and wheel bearings.
Did install a few things (intake and catch can). Hopefully this next week I will have my fmic installed if the pipes get back from powder coat.
Also took an update pic of her
IMG_2025 by RH-Images, on Flickr
Old 07-12-2014, 12:00 PM   #31
robbyh
Member#: 326959
2004 wrx
black
Update with the FMIC installed
Old 07-25-2014, 06:14 PM   #32
robbyh
Member#: 326959
2004 wrx
black
Time to start a new project for the little car. Starting a 2.1 stroker build.
EJ20 that spun a few bearings.
Debating on what upgrades to do with the heads if any
Just cracked the block today
First of the new parts to arrive
Old 09-21-2014, 03:07 PM   #33
robbyh
Member#: 326959
2004 wrx
black
Few more of the parts I'm amassing..
Old 09-21-2014, 05:32 PM   #34
Gallo2011
Member#: 268310
2011 SSM STI saloon
Church!
I assume you're planning to bolt on a larger turbo as well?
Gallo2011 is offline   Reply With Quote
Old 09-21-2014, 05:41 PM   #35
robbyh
Member#: 326959
2004 wrx
black
Oh for sure.. Just got back from picking up this...
FP Red w/ 10cm hotside
also came with
Old 09-22-2014, 10:43 AM   #36
Scooby_Wrx
Member#: 257129
2006 Mitsubishi Evo
Damn, nice work!
Scooby_Wrx is offline   Reply With Quote
Old 09-23-2014, 01:19 AM   #37
alw
Member#: 402274
Really nice work!
alw is offline   Reply With Quote
Old 09-23-2014, 10:47 AM   #38
xhjgjs
Member#: 402310
Congrats! Throw those tail light tints into a volcano, just to be sure!
xhjgjs is offline   Reply With Quote
Old 11-12-2014, 06:41 PM   #39
robbyh
Member#: 326959
2004 wrx
black
Time for another update...
IMG_4138 by RH-Images, on Flickr
IMG_4148 by RH-Images, on Flickr
IMG_4169 by RH-Images, on Flickr
Old 11-12-2014, 06:58 PM   #40
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
damn dude. that thing looks 10,000x better than post 1.
Old 11-12-2014, 09:50 PM   #41
robbyh
Member#: 326959
2004 wrx
black
thanks. It's still a work in progress
Old 11-13-2014, 12:00 AM   #42
blkstar15
Member#: 363892
2013 WRX Hatch Prem
amazing job!
blkstar15 is offline   Reply With Quote
Old 11-13-2014, 12:29 AM   #43
bcvngfhf
Member#: 406207
Installed downpipe today and then ups showed up with this so I had to install it too
bcvngfhf is offline   Reply With Quote
Old 01-18-2015, 01:13 AM   #44
robbyh
Member#: 326959
2004 wrx
black
Another update:
Still amassing parts for this build. Almost at the 5k mark just in parts but I have just about everything I want.. Still need gauges and cluster and some other odds and ends.
Hopefully in the next few weeks I'll drop the block and heads off at the machine shop, depends on funds though.
Disassembled the heads
All the stock stuff valve componets
All new BC Intake & Exhaust valves and BC springs and titanium retainers
BC 280 deg. cams
new STI crank
Old 02-08-2015, 05:38 PM   #45
robbyh
Member#: 326959
2004 wrx
black
more updates for the cars progress
parts came back from machining
heads fully assembled (280 BC cams, Titanium BC retainers and springs, BC valves)
Short block getting assembled
pistons in, ARP head studs in and my little one helping with the build
and where I'm at now.. trying to see what little odds and ins I'm missing r need to get since it was only a partial motor when I got it.
Old 02-08-2015, 06:01 PM   #46
hudsonvalleybugeye
Member#: 295068
2001 forester
I want to learn how to build a motor.
Good work.
hudsonvalleybugeye is offline   Reply With Quote
Old 02-08-2015, 06:14 PM   #47
robbyh
Member#: 326959
2004 wrx
black
the internet and a factory service manual helps a lot.
Old 02-09-2015, 07:37 AM   #48
hudsonvalleybugeye
Member#: 295068
2001 forester
Oh, it will happen. I've always worked on my own stuff, but I've never had a motor out or apart. Aside from minor small engine mechanics.
My daughter is 18 months old now and every time I do something around the house she's always right there, trying to help. I can already tell she's going to be my little helper. One day we will build on something together.
We're house shopping right now, and a garage is on the list!
Anyway, I've chickenhawked this thread enough already.
Get back to your build!
Old 02-09-2015, 10:01 AM   #49
WRXingAbout
Member#: 409939
2015 WRX Limited
Icy Silver Metallic
Very cool. I've enjoyed reading through your post.
WRXingAbout is offline   Reply With Quote
Old 03-14-2015, 09:51 PM   #50
robbyh
Member#: 326959
2004 wrx
black
Another update.. Getting so close to swap time
And before anyone points it out yeah I learned I had the wrong crank gear installed. I swapped it out for a new one lastnight
Little guy next to "his" motor as he says
new fuel line setup (going for a stealth look)
just about done..
and for a for sh$$s and giggles I picked up a 2nd block and heads. Couldn't pass on the price. Not sure what I'll build it into yet.. or what I'll do with it.
