Old 08-05-2012, 10:47 PM   #1
Charlton
Member#: 43038
2002 Forester S
Default EJ25 Head Gasket Failure
Just bought a 152000 mile Forester with a EJ25.
When do the head gaskets fail typically?
What are the symptoms of a failing head gasket?
Charlton is offline   Reply With Quote
Old 08-05-2012, 11:49 PM   #2
J.Gibbs
Member#: 312107
1998 LowFoz
Glacier White
What year is the foz?
They usually go before that. as early as 60k they start to fail. I had 180k on my forester before I HAD to change them.
You can look for bubbles in your coolant overflow tank. Also you can have a test done to see if there are exhaust gases in the coolant.
One sign of major headgasket failure is oil weeping and dripping from the underside of the engine where the head and block meet.
Has the timing belt been replaced yet?
J.Gibbs is offline   Reply With Quote
Old 08-06-2012, 07:35 AM   #3
Charlton
Member#: 43038
2002 Forester S
It's a 2002. Just bought the car so have no idea of service history.
Old 08-06-2012, 10:39 AM   #4
Cefaln452
Member#: 255736
2004 STi
JavaBlackPearl
look where the heads meet the block. if they are all gooey and have oil all over them they are bad.
just did mine on my beater. if you do the valve seals, machine heads, timing belt/wp should run you under 1k if you do it yourself
Cefaln452 is offline   Reply With Quote
Old 08-06-2012, 10:42 AM   #5
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
100k is the *usual* fail midpoint, though with a huge statistical variance . If you don't have a service history, you'd better do some serious maintenance on it, especially the timing belt/ idler pulleys. If that fails = $$$$.
Old 08-06-2012, 12:00 PM   #6
Charlton
Member#: 43038
2002 Forester S
Local Subaru dealer said around $2K to replace head gaskets. I might try calling around dealerships and seeing if they can pull service history off the VIN #.
Old 08-06-2012, 12:04 PM   #7
Charlton
Member#: 43038
2002 Forester S
What are symptoms of issues with timing belt and idler pulleys?
Old 08-06-2012, 02:19 PM   #8
kyle234
Member#: 318405
you're not really going to see any symptoms. best thing to do is pulling the drivers side plastic and take a look its only 3 bolts and you should be able to tell if the belt has been replaced recently.
kyle234 is offline   Reply With Quote
Old 08-06-2012, 04:11 PM   #9
Bluefoton
Member#: 141373
2008 2.5i-hatch -
None until they fail - and their failure is usualy catastrophic as we have interference engines. Common NASIOC wisdom suggest always replacing the pulleys with the timing belt just to play it safe.
