South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 08-06-2012, 02:14 PM   #1
rmblwagon
Member#: 328261
2003 wrx wagon
psm
Default finally got a subie.. need a little help.. reno
Hey guys just got my new to me subie 03 wagon im only the 2nd owner. Ne way been trying to track down this boost oslilation problem for the past 2 weeks and no luck yet .. any one in the reno area care to help a newb out im new to turbos in general. Itd be great to meet some locals.. thanks
rmblwagon is offline   Reply With Quote
Old 08-06-2012, 02:43 PM   #2
Converted STi
Member#: 227723
20XX 5.0
Booosssttttteeeddddd
Can you provide some more details? What exactly is occurring, at what RPM range, what are your boost levels, etc..
Converted STi is offline   Reply With Quote
Old 08-06-2012, 02:47 PM   #3
rmblwagon
Member#: 328261
2003 wrx wagon
psm
Well i bought the car completely stock about a month ago and threw on.a cat back and felt like the car was losing boost so i got a boost gauge and noticed as soon as i hit wot it will hit like 16psi and then fall to 10 than back to 15 and so on till i let off its got 120000 miles. I went to subaru cause i couldnt feel that restrictor pill so i bought that with the new t and the 3 lines goin into them. I tried to clean my bcs lastnight with it in test mode and heard absolutley no clicking from the bcs. Could that be the problem? Thank you
Old 08-06-2012, 02:58 PM   #4
Converted STi
Member#: 227723
20XX 5.0
On a completely stock 2.0L WRX the boost should peak out at about 13psi if I recall, and then taper back. It definitely shouldn't peak, taper, then peak again. Kind of hard to diagnose online, I would try and get some logs and go from there. If you can't you can always try a new bcs, and see what happens. It just sucks throwing money at a problem without having a little more info on it.
Old 08-06-2012, 03:15 PM   #5
rmblwagon
Member#: 328261
2003 wrx wagon
psm
Yea i know i want it to go away it sucks.. and ive been searching so much. Thats why i started replacing lines and the pill i dont know how much subaeu wants for a bcs yet but im sure alot.. i was hopin to find someone local and try there bcs before i start buyin stuff. How do i log stuff? Sorry if that's a dumb ass question i came from a 99 camaro ss ..ha
Old 08-06-2012, 03:26 PM   #6
03.dub.r.x
Member#: 307997
1996 Impreza
Glacier White (230)
my assumption maybe. i know this more then wrong but might be an idea.
your stock exhaust creates back pressure to the turbo so now that you opened up the back end there is no pressure. thus makin you spool then taper then your ecu thinks "hey no back pressure let me boost some more"
i saw this once online and not sure of accurate more then likelynot the root cause of your problem
03.dub.r.x is offline   Reply With Quote
Old 08-06-2012, 03:28 PM   #7
J-MAN08
Member#: 165002
rmblwagon check out the reno subi's @ http://www.seccs.org
J-MAN08 is offline   Reply With Quote
Old 08-06-2012, 03:33 PM   #8
rmblwagon
Member#: 328261
2003 wrx wagon
psm
03.dub.rx i would put the stock exhaust back bit it was there before i did the catback..
jman08 ill check it out
Old 08-06-2012, 03:35 PM   #9
Converted STi
Member#: 227723
20XX 5.0
A tactrix cable is probably the most cost effective route. Accessport will work also, but they are a waste of money IMO. The lines were a good inexpensive place to start. I would assume the stealership will want quite a bit for a new bcs. You might get lucky and find someone locally that has one you can try out, but I would be a little surprised. I have a couple laying around, if you need one let me know. I know it sounds dumb, but have you reset the ECU yet? Might be worth a shot.
Old 08-06-2012, 03:55 PM   #10
rmblwagon
Member#: 328261
2003 wrx wagon
psm
Ill look around for a cable to buy than. And yea after i put in the cat back and drop in k&n. Well actually during the install of the 2 i disconnected the battery.. does your bcs click i put my car in test mode lastnight to clean the bcs and even up to my ear i heard nothing? Are you in the reno area?
Old 08-07-2012, 12:38 AM   #11
Converted STi
Member#: 227723
20XX 5.0
My car is pretty heavily modified, and I'm using an HKS EVC, so I'm not sure, and I can't recall right off. You will be fine with the older tactrix cable, assuming you can find someone willing to part with one. Other wise just visit their site Tactrix. I live in Phoenix, but I am out in Vegas working for a few more weeks.
Old 08-07-2012, 05:32 PM   #12
rmblwagon
Member#: 328261
2003 wrx wagon
psm
My buddy had a 07 wrx he sold and he said he had a logging cable so that should work for mine right. Dang i wish you were a little closer vegas is good 6 hours from reno.
