Old 08-06-2012, 07:40 PM   #1
Merko
Member#: 317488
1995 GC8C WRX import
Default 95 WRX - Removing over-boost fuel cut
Hi guys, I've got a 95 WRX, relevant mods being VF34, 3" turbo back exhaust, Walbro fuel pump and Z4 ECU (15.65psi fuel cut). A couple of months ago I raised boost to about 16psi with my MBC and the car would hit fuel cut at about 4500-5000rpm at WOT, which was when it would hit the 15.65psi fuel cut. We fixed this by tricking the MAP sensor and putting a one-way valve into the air hose for it so that it would only detect vacuum but no boost. This has worked perfectly for the past month or 2, but now it's suddenly hitting fuel cut again... and I can't figure out why! I've swapped that one-way valve for a brand new one to see if it just broke, but it's still happening. I've reset the ECU in the hopes that might do something but it hasn't. I have a spare MAP sensor so I'll try putting that in next. It's just weird that it was fine for this long with the one-way valve trick and now suddenly it's not :/
Is there anything else that controls fuel cut from overboost apart from the MAP sensor? Is it possible to just run no MAP sensor? Any other ideas?
Thanks
Merko is offline   Reply With Quote
Old 08-07-2012, 12:17 AM   #2
RallySport Direct
NASIOC Storefront Vendor
Member#: 33174
We are Open Late!
888-457-2559 Every day!
There are a few Fuel cut Defenders on the market. I ran the HKS "Fuel cut defencer" on my old EJ20G's awhile back and they worked perfectly
Hope this helps.
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
Old 08-07-2012, 12:30 AM   #3
Merko
Member#: 317488
Yeah I was looking at the HKS unit but was hoping to avoid one altogether as my setup has worked and should still be working. But might end up going down that road. Where do you wire the defencer in? The MAP sensor wires or some wires at the ECU?
Thanks
Old 08-07-2012, 09:37 AM   #4
pmugabi
Member#: 280926
Maybe the one way valve is leaking?
I used a similar setup for a few months at one time and it worked perfectly. Although it was not a one way valve, it was simply a T inline with the MAP sensor with one side left to the atmosphere (I know unmetered air etc, but it worked fine).
Another option is to put the 97+ MAP sensor, which is what I'm using now, by default it will cut boost at 1.5bar. It has a different electrical socket, so there is a bit of re-wiring to do.
pmugabi is offline   Reply With Quote
Old 08-07-2012, 12:53 PM   #5
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
If the valve was leaking I would think replacing it would have done the trick.
As to the 97+ MAP sensor. I would think that using Sensor that max's out at a higher value would require the ecu to have a new or rewritten table of MAP sensor values in the same way that a giant MAF sensor cannot simply be dropped in without a new tune that correctly interprets MAF values from a sensor with a higher max value.
As to the OP question, Do you have any datalogs with MAP sensor readings from before and now?
Is it possible that you have a vacuum leak somwhere else that is effecting the functionality of your one way valve. I dont think the ECU would typically let something doesnt run for months and stop working. If the ECU somehow relearned its usually in 2 weeks not 2 months.
TommyAtomic is offline   Reply With Quote
Old 08-07-2012, 01:19 PM   #6
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Over on Legacy Central, there is a sticky on how to make your own FCD. The one they describe there will work on an EJ20G just as it works on an Ej22T.
Old 08-07-2012, 06:43 PM   #7
Merko
Member#: 317488
I've checked for vacuum leaks and can't see any. I am stumped as to why it's suddenly started cutting again. I don't see how it's possible if the MAP isn't getting the pressure! And it's definitely boost cut because if I drop the boost a few PSI it will boost perfectly. Maybe the MAP is faulty? I'm still going to put my spare on there and see what that does.
But anyway, I bit the bullet and bought a HKS fuel cut defencer off eBay for $60. Hopefully that fixes it, or at least it'll tell me the problem is somewhere else.
