Old 08-01-2012, 12:24 PM   #1
Devc
Member#: 218437
1992 Lego SS/Stagea
Default Acl Bearing reuse
Put in a set of std size acl race bearings in my ej22t and ran it for less then 50km, tore the engine apart again for forged pistons, sould I buy new bearings again or should I re-use these ones, crank surface looks great, but the bearing doesnt look as fresh as when they where installed, has some small marks on them in some spots.
I'll try to get some pics tonight.
Devc is offline   Reply With Quote
Old 08-02-2012, 07:38 AM   #2
renhoek
Member#: 71339
1995 WRX STi RA
1995 WRX STi LS1
For such low use I would re-use. Those bearings are not like head gaskets, which of course you must replace.
renhoek is offline   Reply With Quote
Old 08-03-2012, 03:25 AM   #3
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
If they look good reuse them, no problem.
Marnix is offline   Reply With Quote
Old 08-03-2012, 10:43 AM   #4
simer1228
Member#: 171039
99 RSTi Type-R LTD
Black Diamond Pearl
Probably wouldn't hurt to measure the clearances with some plastigauge. It's cheap and quick and won't leave you wondering if your clearances are out of whack or not.
simer1228 is offline   Reply With Quote
Old 08-04-2012, 12:02 AM   #5
RallySport Direct
NASIOC Storefront Vendor
Member#: 33174
We are Open Late!
888-457-2559 Every day!
Yeah I would also double check the tolerances just to make sure, but like others have said, if they are in good condition, you are good to re-use them,
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
Old 08-05-2012, 12:02 AM   #6
sense of nature
Member#: 112759
2018 STi Mikey Tuned
SexyRP
Looks measure, measure,MEASURE!
Right on!
Thanks,
Rick
Double & triple check
I've re-used them after 30k or so.. but they spec'd out correctly of course!
sense of nature is offline   Reply With Quote
Old 08-05-2012, 01:09 AM   #7
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
If the bearings were measured when installing them first time and they are to be used on the same block/crank/rod combination and show no (obvious) signs of wear I'm pretty sure the will still be within spec!
In all other cases you are right ofcourse.
Old 08-08-2012, 07:30 AM   #8
renhoek
Member#: 71339
1995 WRX STi RA
1995 WRX STi LS1
^+1. :d
