Old 08-07-2012, 05:14 PM   #1
Uruchima
Member#: 322246
2013 WRX Sedan
Have a Nice Day? 2009 2.5i Impreza Catalytic Converter
Hey Folks,
I'm trying to look for a High-Flow Cat for my Subaru 2.5i Impreza (hatchback) and I've looked at a fiche blueprint of the exhaust system--I was trying to find the size of the pipping--and I noticed the cat is attached to a pipe which then connects to the exhaust manifold (if I'm not mistaken)
here is the fiche for the exhaust:
I have a OBX WRX Catback Exhaust installed and I'm looking to get a high-flow cat but after looking at this fiche I don't know if I need a custom high-Flow cat or get something off a WRX or a Legacy Aftermarket.... any suggestions/ideas/help?
If it's just a high flow cat that I need, what is the length and in/out width of pipping?
Goal: High Flow Cat
Uruchima is offline   Reply With Quote
Old 08-08-2012, 10:54 PM   #2
scoobymatt93
Member#: 254115
2009 Impreza 2.5i
Dark Grey Metallic
The cat is built into the header. Honestly, I'm pretty sure a HFC will do nearly nothing for you. If you'd want, you could either get some custom headers built (cough Rallisport Racing UEL headers), or you could chop up your stock header (which I definitely wouldn't want to be doing.
scoobymatt93 is offline   Reply With Quote
Old 08-09-2012, 01:04 AM   #3
bugeyetex
Member#: 283815
2003 psm wrx wagon
Built Fuji Tough
Change your goal to a high flowing exhaust system. Replace the whole thing, not just the cats if you want to do anything besides taking the sugar pill... Its not turbocharged, so you wont see any real gains unless you do the whole system.
bugeyetex is offline   Reply With Quote
Old 08-09-2012, 02:11 AM   #4
alt14
Member#: 271928
2014 WRX Limited
Crystal Black Silica
Wait for Rallisport performance headers and a high flow second cat.. or gut it, I won't suggest going bigger than 2.5 inch pipping though
alt14 is offline   Reply With Quote
Old 08-10-2012, 11:10 AM   #5
Uruchima
Member#: 322246
2013 WRX Sedan
The obx wrx exhaust I have is 2.5in and also has a nice back pressure for exhaust velocity. Let's see when rallisport gets their headers. I will ask you this question, I'm getting ready to do a stage 1 tune...
Should I go to colder spark plugs like from a wrx, since I have to change them this weekend anyways?
I have a Cosmo racing CAI and the obx exhaust, stage 1 tune will be open source...
Old 08-10-2012, 11:50 AM   #6
treksofar
Member#: 208070
2006 Impreza 2.5i
Regal Pearl Blue
Instant high flow cat system on the cheap....remove the 2nd cat completely. Technically you only need one but since the car has 2 cylinder bangs the EPA (or california) requires 1 cat for each bank.
treksofar is offline   Reply With Quote
Old 08-10-2012, 11:58 AM   #7
Uruchima
Member#: 322246
2013 WRX Sedan
Good thing I'm not in California... should I test pipe it? Or gut the cat?
Old 08-10-2012, 12:04 PM   #8
treksofar
Member#: 208070
2006 Impreza 2.5i
Regal Pearl Blue
test pipe. hell while ur at it just take the entire cat and midpipe/resonator section out and replace with a piece of 2.5" exhaust tubing.
Old 08-10-2012, 12:06 PM   #9
treksofar
Member#: 208070
2006 Impreza 2.5i
Regal Pearl Blue
a good exhaust shop should be able to set u up for around $200 or less.
Old 08-10-2012, 12:32 PM   #10
Uruchima
Member#: 322246
2013 WRX Sedan
I have a obx cat back already, so straight pipe from the heads to the exhaust should be all I need...
Old 08-10-2012, 12:34 PM   #11
Uruchima
Member#: 322246
2013 WRX Sedan
Any response about the spark plugs? I'm getting a stage 1 tune, should I upgrade them to wrx plugs?
Old 08-10-2012, 03:17 PM   #12
treksofar
Member#: 208070
2006 Impreza 2.5i
Regal Pearl Blue
You're really not going to see chamber pressure/temperature in your engine that will warrent the need for cold plugs. Just use the NGK irriduim plugs spec'ed for your car and you'll be fine.
Old 08-10-2012, 04:35 PM   #13
alt14
Member#: 271928
2014 WRX Limited
Ngks like he said are all you really need
Old 08-11-2012, 02:13 AM   #14
Bababou
Member#: 280689
2010 2.5i Impreza
Newport blue
Ive been looking at removing the second cat on my '10 impreza have not done it yet but alot of post Ive read suggest putting a resonator in place of the cat to keep it from getting to raspy.
Bababou is offline   Reply With Quote
Old 08-11-2012, 02:49 PM   #15
Uruchima
Member#: 322246
2013 WRX Sedan
Got the ngks, oil change too, I'm racing next weekend, what I saw when I looked under the car that the cat has its own pipe detachable from the headers. I might see if can change that pipe out and see what happens. It'll definitely help my stage 1 tune.
Old 08-13-2012, 01:07 AM   #16
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
[annoyed]Backpressure does not induce exhaust velocity. Backpressure is bad, period.[/annoyed]
Counterfit is offline   Reply With Quote
Old 08-13-2012, 01:51 AM   #17
Bababou
Member#: 280689
2010 2.5i Impreza
Newport blue
There are two cats, one in the header and then the one your refering to. The second one is the one to remove / change and it is not monitored.
Old 11-01-2012, 01:14 PM   #18
09subi2.5i
Member#: 331636
09 impreza
paprika
The second one is the one to remove for what reason? i have a stock exhaust on my 2.5i and i really am not looking to necessarily increase the sound as much as i just want to be able to employ that boxer rumble. i also would not like to void my warranty. what are my best options? i was thinking of a test pipe but after reading this i guess should i just do headers?
09subi2.5i is offline   Reply With Quote
Old 11-01-2012, 01:25 PM   #19
NH8991
Member#: 197937
2016 Golf R
Under the radar silver
If you don't want to take the chance of having your warranty voided a claim denied then leave the car stock, period. (Very few people get their warranty voided, more often it's when you make a claim and Subaru won't entertain it on the grounds that your (insert modification here) caused/contributed to the failure.)
Yep, if you want the boxer rumble then you need UEL headers.
NH8991 is offline   Reply With Quote
