Welcome to the North American Subaru Impreza Owners Club Tuesday July 7, 2015
Old 08-07-2012, 09:36 PM   #1
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Default Temperature randomly fluctuates
Just bought a 99 forester. On the way home, the temp gauge started fluctuating randomly. I'd come to a stop, it would shoot up, then drop down. Or it would stay up for a while. Or it would go up when just driving. Tried to turn the heater on to relieve the readiator, but found that it got warm then tuned cold. noticed when it turns cold, the temps shoot up. I've read through the other threads, but wasn't sure the other threads, not sure what the best way to tackle this problem:
Bad Thermostat ?
Bad Water pump?
Probably not a bad head gasket as it would have to be sever and I don't have any coolant in the oil and don't have any white reside on the oil cap.
What would you guys recommend?
Bad Noodle is offline   Reply With Quote
Old 08-07-2012, 10:01 PM   #2
cal_look_zero
Member#: 294461
1997 Outback Sport
383hp/345tq
Bad T stat for sure. Cold heater is a giveaway for that. Get a stant xact-stat or OEM. Don't buy a parts store replacement. Not sure why eactly, but Subis hate cheap t stats.
cal_look_zero is offline   Reply With Quote
Old 08-07-2012, 10:48 PM   #3
mod maniac
Member#: 300551
2&4 fxt & fxt sti
Fullers Garage
When the heater stops working there is no water in it. You either have a leak or a bad hg. subaru's usually don,t get water into the oil when the hg is bad.
Old 08-08-2012, 06:36 AM   #4
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
This. I drove 40 miles and lost all the fluid in the radiator. No visible leaks when the car is off or idling, which leaves me with the head gasket.
Old 08-08-2012, 09:15 AM   #5
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
Well if you lost all fluid while driving there might have been nothing left to leak out
Old 08-08-2012, 09:49 AM   #6
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Checked multiple times with full rad at idle before going on test drive
Old 08-08-2012, 06:41 PM   #7
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
I wonder if your water pump is starting to die. Even if the thermostat is stuck open, the heater should still have hot water going through it. If the water stops circulating, the heater will cool off. But a sure way to tell is to remove the thermostat and put it in a pot of hot/boiling water and observe. It's the cheapest place to start.
Old 08-11-2012, 04:08 PM   #8
giosoccer20
Member#: 328622
1999 Impreza 2.5 RS
I have this problem of a fluctuating temp gauge, it goes from normal to high, then when i drive over 30mph it goes back down to normal -_-. I don't get it at all. But I have actually found a visible water leak, and the CEL is on.
giosoccer20 is offline   Reply With Quote
Old 08-12-2012, 04:09 PM   #9
AWDmonk
Member#: 271442
2006 Impreza 2.5i
CGM
Could be a slow leak not related to the head gasket. It's possible that when you checked the rad, all the coolant was in the block. Fill up the rad and bleed the system a couple times.
AWDmonk is offline   Reply With Quote
Old 08-12-2012, 10:02 PM   #10
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
10-4 did that and still the same result before I drove the car I made sure the system was 100% free of air. Then I found a couple service bullitins in the na thread describing this common problem.
Apparently if you have an external leak, it can be fixed with the coolant conditioner according to subaru. But if you have an internal leak, you will see no signs except the symptoms I'm seeing.
Old 08-13-2012, 12:15 PM   #11
aclver1
Member#: 114177
2004 Impreza 2.5rs
70 Datsun Fairlady
Check your rad cap or just get a new one, they are cheap. If it can't hold the pressure you will see high temps at low speeds but once you are at higher speed there is enough cooling to keep temps down.
As for the OP I think you may have multiple issues. Start with the cheap and easy and work down.
aclver1 is offline   Reply With Quote
Old 08-13-2012, 03:06 PM   #12
mod maniac
Member#: 300551
2&4 fxt & fxt sti
Fullers Garage
That is exactly the way I see it all the time. hg's
