#1 |
Member#: 156247
Vehicle:05 STI-10.6 @ 134 GTR - 9.31 @ 151.78 |
Event: Dyno Tune !
Location: Accelerated Performance| Toledo, OH Ambient Temp: 80 degrees Elevation: 790-800ft Weather: Pretty Warm Car: 2012 Subaru BRZ Tuner: Visconti Dyno Info: DynoJet 224 Peak HP at RPM: 278 @ 7200 Peak Torque at RPM: 215 @ 5500 Baseline hp/tq for a stock on same dyno: 161WHP/136WTQ Target AFR: ![]() Fuel: Straight 93 unleaded Engine/Power Modifications: Stock Header, Accelerated Performance BRZ-300 Turbo Kit @ 10PSI, OMNI 4 BAR Map Sensor Well it's been a few weeks since I first posted up the results of this turbo kit on low boost.. Last time on the dyno we ran into ecu limits preventing us from increasing the boost. Since then EcuTek has been working super hard on defining this ECU. Well their hard work paid off because now this car is taking boost like a champ! ![]() I'll post up more info later - Have a turbo automatic to tune tomorrow so need to get ready for that! -John
#2 |
Member#: 261612
Vehicle:2011 WRX 5 Door NF Performance Stage 1 |
Wow, those results look great! That is such a linear powerband!
#3 |
Member#: 41762
International
Vehicle:04 STi CT-DE-FL rinse+repeat |
Very nice. Do you think that's about all the boost it can take unless you lower the compression? Or is there more on the table?
#4 |
Member#: 120461
BAIC
Vehicle:2004 WRX STi JBP |
stock header??
#5 |
Member#: 210777
SCIC
Vehicle:.. Don't worry bout' it Brah |
Do headers and a full straight pipe...
#6 |
Member#: 156247
I think it'll make a little more with a header and larger injections.
Port Injectors are maxed out and I dont trust the direct injection enough to increase the volume of fuel coming out of them for additional hp.. -John |
#7 |
Member#: 210777
SCIC
#8 |
Member#: 156247
Fuel volume is not a problem at this point in time - so no boostapump
![]() I have a few different sized injectors from Spray It Racing coming that I need to try out. This is a good power level for this car right now. Once I get the Per Gear Boost Control from EcuTek we can start turning up the boost - until then it'll be pointless. -John |
#9 | |
Member#: 210777
SCIC
#10 |
Member#: 156247
#11 |
Member#: 33174
RMIC
Vehicle:We are Open Late! 888-457-2559 Every day! |
Wow nice, and the numbers just keep growing and growing!
![]() Thanks, Rick |
#12 |
Member#: 126696
SWIC
Vehicle:2002 Fatbody bugeye 03 R1 09 Raptor 700R |
I'm curious to know why these cars aren't making torque like our boxers...(wrx/legacy/fozz/etc)
Besides the obvious 2.5L reasoning...I'm talking 2L to 2L...RWD? Last edited by domestic_abuser; 08-08-2012 at 05:53 AM. |
#13 |
Member#: 278519
SCIC
Vehicle:KBiz KeeganLB 30rSTI phatron tuned |
reminds me of the low torque from any other fwd turbo'd honda, its the reason all of those guys even with 500+whp go to a lower hp subie, the torque being so low and the traction
#14 |
Member#: 123625
Vehicle:2002 wrx vf34 Tuned at Cobb |
What is the price point of these turbo kits? any smaller turbo options?
#15 | ||
Member#: 156247
If I were to put a 10PSI spring in it I think it would come on harder Quote:
Smaller - Nope, only bigger ![]() -John |
#16 |
Member#: 261612
Does this motor use a cam driven fuel pump? Has it been considered when increasing power? I know that on some other direct injection platforms it is a huge limitation, and is often replaced if you're going to do anything past stock or Stage 1.
#17 |
Member#: 81102
Good job, John. Nice to see u on the leading edge.
Carmi |
#18 | |
Member#: 156247
I've increased the demand on the direct injection system a good amount - but having tuned other DI platforms i know what kinda mess could lie ahead. This is why during WOT I mostly use Port Injection - but nothing to date has given me any concerns on this DI system - works SURPRISING well. I think its fair to assume Toyota & Subaru didn't ask for Mazda's help lol -John Thanks |
#19 |
Member#: 142608
TXIC
Vehicle:2003 Sonic Yellow Marginally well behaved. |
Awesome job guys! Graph looks really nice.
Does the BRZ come from the factory with port injection and direct injection? Or did you add the port injection for the turbo kit? |
#20 |
Member#: 156247
#21 |
Member#: 125580
Vehicle:2011 WRX 5dr OBP |
So what's it like to drive now?
#22 |
Member#: 142608
TXIC
#23 |
Member#: 81102
http://www.ft86club.com/forums/showthread.php?t=3172
http://www.ft86club.com/forums/showthread.php?t=6572 Direct is for wot and port for startup/idle, no? |
#24 | |
Member#: 156247
To be honest the way it's setup from the factory doesn't make 100% sense to me. During WOT in the midrange its only using Direct -John |
#25 |
Member#: 142608
TXIC
