Old 08-08-2012, 02:27 AM   #1
Spy
Member#: 60062
2000 Impreza 2.5RS
2009 Norco Team DH
Default GC: Rough idle and hesitation
My 2000 Impreza RS sometimes has a rough idle and some hesitation in lower RPMs, < 3000. Hoping someone with more knowledge might be able to help me out.
It seems like it only does it when its warm, but not all the time. On and off.
It has thrown two codes:
P0136 - Rear 02 sensor circuit malfunction
P0139 - Rear 02 sensor slow response
After I cleared these two codes, they haven't come back so I am hesitant to replace the expensive sensors if they aren't what is causing the problem.
Car seems to run a bit rich.
Coolant is normal colour and isn't burning or anything so I don't think its the head gasket.
-Timing belt: Recently replaced, tensioner was reused. Car ran perfect after with the new belt for some time before this happened.
-Oil and air filter changes have been done regularly
-Fuel filter hasn't been changed in quite some time
-Almost new spark plugs
-Spark plug wires haven't been changed in a long time, seem fine though
-Can't see any exhaust leaks
Here is the live data, maybe someone if able to tell if something doesn't look right. (Unfortunately, this was when the car was cold and idling fine)
https://www.dropbox.com/s/92md4cn72o...%2049%20PM.jpg
https://www.dropbox.com/s/8iwdw59z1p...%2041%20PM.jpg
Thanks for your help.
Spy is offline   Reply With Quote
Old 08-08-2012, 08:19 PM   #2
Spy
Member#: 60062
2000 Impreza 2.5RS
2009 Norco Team DH
bumb! please help. Hesitation seemed to get worse a bit on the way to work today.
When I'm driving and then stop. Immediately after the idle is OK, but as I sit there idling it gets worse and worse. It doesn't stall, but gets close. And then it's hard to get going again sometimes as there is not power... feels like I have no gas and the car just bogs out, but I have lots of gas. Once I'm in higher RPM's there is no problem.
Old 08-09-2012, 12:42 AM   #3
nasiocjunkie
Member#: 80864
I'll have the tuna.
No crust.
http://www.rs25.com/forums/f13/t6639...ere-first.html
If you're getting those codes then you should test your o2 sensor. If you don't know how to test it just change it out and see if it solved your problem (mine cost me about $68 at O'Reilly's Auto). Also you may want to clean or get your maf checked out with a scanner.
nasiocjunkie is offline   Reply With Quote
