Old 08-08-2012, 02:40 PM   #1
Charlton
Member#: 43038
2002 Forester S
Default Do Coolant Levels Fluctuate in the Reservoir?
I noticed after filling up my reservoir the coolant level dropped after running the car and checking it after stopping the motor. There is no bubbles in the reservoir, no coolant smell nor coolant on the driveway or in the oil.
Is this normal or am I magically losing coolant lol?
Charlton is offline   Reply With Quote
Old 08-08-2012, 02:43 PM   #2
abosworth
Member#: 53856
2012 Speed3
Red Mica
Yes, the levels will fluctuate a little bit depending on whether it's hot or cold. How much is it going down?
abosworth is offline   Reply With Quote
Old 08-08-2012, 03:11 PM   #3
GEE-OTTO
Member#: 201277
2009 Legacy GT
When my car was new (2008 Legacy 2.5i) with 2 miles on the clock the reservoir was nearly empty the dealer said it was normal i drove it for 103K miles like that through 100+ degree heat and single digit lows, never had a problem. When i replaced the TB and related components i filled the reservoir up to the cold line to be sure for the next 100K miles.
GEE-OTTO is offline   Reply With Quote
Old 08-08-2012, 03:13 PM   #4
T Wrex--OH
Member#: 179478
2000 Impreza 2.5 RS
Sedona Red Pearl
When the car is cold, keep an eye on the resevoir while pulling off the radiator cap. Voila! coolant will "magically" reappear in the resevoir.
T Wrex--OH is offline   Reply With Quote
Old 08-08-2012, 04:11 PM   #5
Charlton
Member#: 43038
2002 Forester S
Maybe a couple inches.
Old 08-08-2012, 04:23 PM   #6
abosworth
Member#: 53856
2012 Speed3
Red Mica
That seems about normal.
Old 08-08-2012, 08:07 PM   #7
bugeyetex
Member#: 283815
2003 psm wrx wagon
Built Fuji Tough
I might think about changing the coolant out. Just like oil, you should change your coolant, not every 3-5k, but usually either 30-60k is recommended by the manufacturer and the ones that say 100k... I don't really believe. Just like I wont recommend that you change your oil every 7500mi which is what most new vehicles state in the owners manual, maybe with synthetic... This all comes down to Cost of Ownership when comparing cars. The less that the manufacturer recommends to do, the less the cost of ownership is on paper for those who look at that when they buy new cars.
bugeyetex is offline   Reply With Quote
