Old 08-08-2012, 02:43 PM   #1
Charlton
Member#: 43038
2002 Forester S
Default High Mileage Oil in Phase II EJ25 SOHC
Advanced Auto was running a special yesterday on 5 quarts and a free filter for $24.99.
I used the Castrol High Mileage 10w-30 in my 2002 Subaru Forester.
What oil are you folks using on high mileage vehicles? Did I make a good choice?
Charlton is offline   Reply With Quote
Old 08-08-2012, 04:48 PM   #2
STi Guy 69er
Member#: 82648
2005 Impreza 2.5 RS
Oil is oil unless you buy expensive oil like mobil 1 or royal purple. Every oil has a different additive in it to help prolong the life of the oil due to the companies testing but all in all if they meet specs on the back of the bottle they r all the same. Change oil when every 3000 miles or 5k. Personally i know all oils break down before this amount of mileage due to the reason oil life is actually based on engine hrs not mileage.
STi Guy 69er is offline   Reply With Quote
Old 08-08-2012, 04:57 PM   #3
Charlton
Member#: 43038
2002 Forester S
I was going to split the difference and do every 4,000 mile intervals or 5 months.
Old 08-08-2012, 05:41 PM   #4
cal_look_zero
Member#: 294461
1997 Outback Sport
Acadia Green Metallic
I run Rotella T/5/6 depending on vehicle application. $13 a gallon for the basic stuff leaves more money to spend on a quality filter like Bosch or Purolator.
I was running the Rotella T in an EA82 Subi with 336k miles on the clock. No issues. Might save you some $$ later on.
cal_look_zero is offline   Reply With Quote
Old 08-08-2012, 06:07 PM   #5
FCmaniac
Member#: 142029
2013 Fozz
2004 STi, 1991 Miata BRG
I've been running Valvoline NextGen Maxlife high mileage 5w30 in my 01 Forester. I need to get an oil analysis to tell what is really going on.
FCmaniac is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 04:05 PM.
