Go Back   NASIOC > NASIOC Technical > FA Series Normally Aspirated Powertrain
Old 08-08-2012, 05:35 PM   #1
DeatschWerks
Member#: 87358
Default BRZ Fuel System Component Walkthrough
BRZ OE PORT Fuel System Review…
PART 1: PORT FUEL INJECTORS
Subaru PN: 16611AA860
Manufacturer: Denso
OE PN: 2040
Testing Data:
Flow Data Summary:
Static Flow: 205cc/min at 43.5psi (3bar)
Spray Pattern: dual beam – split V (~10*)
Dynamic Flow: see reports for detailed flow data
Injector Description:
The Denso injector used in the BRZ is different from a lot of other injectors. The injector utilizes a 11mm upper o-ring, sumitomo electrical connector, and a high impedance 12.3ohm coil, which is all fairly common. However, the injector body is very short (40mm functional length) and the nozzle is extended 20mm. This yields an overall overall length of 68mm.
Pictures:
BRZ injector (side view)
BRZ injector nozzle (bottom view)
BRZ injector connector (top view)
DeatschWerks is offline   Reply With Quote
Old 08-08-2012, 05:36 PM   #2
DeatschWerks
Member#: 87358
PART 2: FUEL PUMP MODULE
Subaru PN: 42021CA000
Manufacturer: Denso
OE PN: 291100-0090
Testing Data:
Module Description:
The module (aka bucket, aka assembly) is fairly standard in size, shape, and design. The BRZ fuel system appears to be returnless because there is only one outlet on the module (see pics). There is an internal regulator that keeps the system pressure a constant 4 bar (58psi), which also indicates a returnless system. I am not aware of another manifold referenced regulator anywhere else in the system. There is also a post fuel pump filter integrated into the module. Both the pump and internal regulator are held into place with a special pre-filter (aka sock) that has integrated clips. Fuel pump modules often have an effect on flow rates. Therefore the OE pump was flow tested both installed into the module and outside of the module. See the report for detailed flow results.
Pictures:
BRZ module – assembled (side view)
BRZ module – assembled (top view)
BRZ module - opened
Old 08-08-2012, 05:36 PM   #3
DeatschWerks
Member#: 87358
PART 3: FUEL PUMP
Subaru PN: NA – only sold with module
Manufacturer: Denso
OE PN: 291100-1050
Testing Data:
Pump Description:
The first obvious thing to note is that the fuel pump is very small. The overall length is 96mm and the diameter is 38mm. Other than the size, the pump is pretty normal. It features a single stage, single row turbine impeller, internal check valve to hold system pressure and a spring and disc style PRV (pressure release valve). The connector is not a standard style. When tested, the pump operated very quietly and smoothly drawing very little current, but also flowing quite modestly. The PRV begins to opens at 50psi which is interesting given that the internal regulator is set for 58psi. The PRV does not bleed off a lot of fuel so effects on flow are pretty minimal.
Pictures:
BRZ pump (side view)
BRZ pump inlet
BRZ pump outlet
Old 08-08-2012, 06:04 PM   #4
FCmaniac
Member#: 142029
2013 Forester
2008 350z, 1991 Miata BRG
Great info. Thanks for posting it!
FCmaniac is offline   Reply With Quote
Old 08-08-2012, 07:02 PM   #5
chadr111
Member#: 37718
02 TS, (too Slow)
black
What, a vendor in the NA forum? Thank you BRZ!
chadr111 is offline   Reply With Quote
Old 08-09-2012, 12:47 PM   #6
DeatschWerks
Member#: 87358
Got this heads up from an IWSTi Member >
Originally Posted by suby2low
I would like to throw a couple of words of caution out there about the high pressure side of this fuel system. (Have been to some initial training on the FRS). The high pressure side of the fuel system has a built in pressure sensor that we can look at with scan tool data. We have seen pressures just north of 3000 Psi. The cautionary tail is that the high side pressure DOES NOT bleed down when the car is shut off. Even over an extended period of time. A couple of American engineers found this out the hard way. There is a high pressure bleed down procedure using the factory scan tools. Please be careful if you attempt to work on the fuel system.
