Old 02-25-2013, 01:15 PM   #6876
inspectah
Member#: 345290
2013 STI hatch
CBS - on order
Originally Posted by Scoobers View Post
Damn man.... when did you order? I'm guessing Jan13 due to your join date?
And is that two weeks at the dealership for accessories?
I ordered Jan 22, and that's at the dealership
inspectah is offline   Reply With Quote
Old 02-25-2013, 03:07 PM   #6877
digitizedsoul
Member#: 334780
2013 STi Limited 4dr
Crystal Black Silica
Read back several pages for my comments on flashing with cobb's off the shelf maps.
The stock tune is HORRIBLE.
That read's HORRIBLE in english.
It's bad for you, bad for your car, and bad for me when I sleep at night.
It has a 2 second delay for open/closed loop transition, which when you romp on it and build boost quickly, means that you run LEAN until it goes into open loop and lowers the AF/R.
You are more then welcome to go through ALL the effort I and many others have done to end up proving me right, or you can just take my and many others words for it (you read it on the internet, duh?).
FLASH STAGE 1.
I did it within 1hr after picking up my car. 1st time I built boost I nearly puked at the fueling and surging and nonsense.
The end.
digitizedsoul is offline   Reply With Quote
Old 02-25-2013, 03:13 PM   #6878
Studmike02
Member#: 220095
'95 MX-5
Arent you supposed to break in before flashing to stage 1?
Studmike02 is offline   Reply With Quote
Old 02-25-2013, 03:19 PM   #6879
Mr. Lin
Member#: 344988
2013 WRX STi
ISM
the less time on the stock tune, the better. that's how i look at it
Mr. Lin is offline   Reply With Quote
Old 02-25-2013, 03:20 PM   #6880
SubieLuvin
Member#: 248202
2013 WRX Sedan
Logically why would that make sense if stage 1 tune is better than the factory? Wouldn't you want to break the motor in under more ideal running conditions?
It probably won't make much difference either way since you don't build boost much during the break in. But I wouldn't be afraid to flash after rolling it off the lot.
SubieLuvin is offline   Reply With Quote
Old 02-25-2013, 03:29 PM   #6881
digitizedsoul
Member#: 334780
Once you drive the car you'll understand that "not building boost" is simply not an option.
This isn't a 60mm turbo, it will spool as you daily drive around trying to impersonate a 90yr old without her glasses, nothing you can do about that.
What you can do is prevent your ECU from IMPROPERLY FUELING while this is happening.
Old 02-25-2013, 03:30 PM   #6882
luan87us
Member#: 335013
2013 Premium WRX 5dr
FLASH STAGE 1.
The end.
Not everyone a rich engineer like you man!!! I'm on the fence about getting one. Too much money, I have all kind of payments to worry about. May be I should sell my AR15
luan87us is offline   Reply With Quote
Old 02-25-2013, 03:38 PM   #6883
SubieLuvin
Member#: 248202
2013 WRX Sedan
Nvm. Ill be flashing right when I get mine.
Old 02-25-2013, 03:39 PM   #6884
inspectah
Member#: 345290
2013 STI hatch
CBS - on order
Don't know if I could justify getting rid of my AR
Old 02-25-2013, 03:42 PM   #6885
digitizedsoul
Member#: 334780
Oh I completely understood what you were saying, which is why I fashioned the response I did.
See, quick throttle transitions and aggressive driving are not what makes the oem tunes doo doo ability shine.
It needs only input from it's sensors, to exhibit it's horrible calculations and foul everything up. You'll be feeding it plenty of said input regardless of how you drive.
Oh and everyone seems to think that there are no other cars on the road that WILL influence how you drive yours.
Everyone babies their car, until some idiot floors it when you pull out and to avoid being rear ended you have to GO SON GO.
That is just one example, but **** happens you will need to ask your car to answer you at least 20 times in the first 200 miles let alone 1000.
Better to be prepared.
Old 02-25-2013, 03:46 PM   #6886
inspectah
Member#: 345290
2013 STI hatch
CBS - on order
Luckily us NH/Mainers don't have to worry too often about dbags putting you into an uncomfortable position.
Old 02-25-2013, 03:48 PM   #6887
digitizedsoul
Member#: 334780
I wish, i'm in atlanta and this is my daily driver.
Breaking the car in properly was easy, not collecting 20 felony assault charges before I got to work was the challenge.
Old 02-25-2013, 03:52 PM   #6888
SubieLuvin
Member#: 248202
2013 WRX Sedan
Thanks for the responses. Your background in understanding how the ecu works is very useful, just goin back in forth with you around a few threads I've learned quiet a bit and honestly you saved me from making a couple of mistakes with a brand new car.
Cheers. Now to keep waiting...
Old 02-25-2013, 04:24 PM   #6889
localbooster
Member#: 348259
New to the forums but not subies used to have a 04 sti. Went to the dealer last Wednesday and ordered a 2013 wrx will be in march 20!
localbooster is offline   Reply With Quote
Old 02-25-2013, 04:29 PM   #6890
punkNdrublic04
Member#: 273621
2013 WRX Limited
SWP Hatch
Today marks 6 weeks since I ordered. No info yet. I will be calling my dealer in a little bit so see if that have any new info.
punkNdrublic04 is offline   Reply With Quote
Old 02-25-2013, 04:47 PM   #6891
luan87us
Member#: 335013
I can't either but all this madness about Gunpocalypse is driving the ammo price insanely high, HARD to find. The gun is just very hard to enjoy now. I only have about 200 rounds left and it hurts me every time I pull the trigger. I wish they would make up their mind already and either ban or not ban the damn thing. May be I should sell my Barretta instead since I got a 1911 now.
Old 02-25-2013, 05:17 PM   #6892
electric_eel
Member#: 345411
2013 WRX 5dr
4 weeks down.
electric_eel is offline   Reply With Quote
Old 02-25-2013, 05:21 PM   #6893
WRX_Mafia
Member#: 343626
2013 WRX Sedan
I've got an idea, stop pulling the trigger. And don't sell or give up your AR for an aftermarket tune. Not worth it IMO. I'm sure you know that your AR is worth 3x more then what you paid for it under these gun/ammo shortages. Keep it.
On another note, 7 weeks since I ordered my WRX. Should hopefully get a VIN in the next couple of weeks.
WRX_Mafia is offline   Reply With Quote
Old 02-25-2013, 06:47 PM   #6894
luan87us
Member#: 335013
But then my AR15 just sitting there doing nothing but looks pretty lol. It'll probably kill me to sell it. Just a thought
Old 02-25-2013, 07:20 PM   #6895
Scoobers
Member#: 341693
2013 Subaru
13 WRX SWP
FLASH STAGE 1.
The end.
Mainly quoting you guys because you seem to be pretty knowledgeable regarding COBB.
I'm a subienoobie, so this may sound like a retarded question.Please don't flame, I'll set myself on fire
Could I do a stage 1 flash with no modifications? I don't want to do the whole Intake/Exhaust etc.
I didn't plan on doing anything performance wise; however, by the sound of it, it seems like the stage 1 ecu tune is "Better" for the longevity of my car.
Anyone else with knowledge on this, feel free to chime in
Scoobers is offline   Reply With Quote
Old 02-25-2013, 07:24 PM   #6896
Anubis80
Member#: 341903
2013 WRX
Yes you can run stage 1 tune with zero other mods. Go to cobbtuning.com and it will give you all you need. Download the map you want and your done.
Anubis80 is offline   Reply With Quote
Old 02-25-2013, 08:04 PM   #6897
Scoobers
Member#: 341693
2013 Subaru
13 WRX SWP
Thanks Anubis. I found this Chart. I know I wouldn't run the ACN because I don't live in AZ, but other than that, which one would I go for?
I'm probably overthinking this and losing credibility as I post
Old 02-25-2013, 08:17 PM   #6898
Anubis80
Member#: 341903
2013 WRX
Run normal 91 or 93 octane if you have it in your area. Monitor your boost levels and make sure your within target on the map notes.
Trust me the stock OTS cobb maps are very safe and conservative.
Old 02-25-2013, 08:20 PM   #6899
Anubis80
Member#: 341903
2013 WRX
You can PM me if you want when you get it and i will help you out. Like I said i ran the cobb AP on my last 2 cars so i have some decent experience.
Old 02-25-2013, 08:36 PM   #6900
Scoobers
Member#: 341693
2013 Subaru
13 WRX SWP
Sweet... Thanks! I sent you a friend request.
