Welcome to the North American Subaru Impreza Owners Club Sunday February 1, 2015
Old 08-08-2012, 10:40 PM   #1
nyrangerfan222
Member#: 308858
2014 wrx hatch
Plasma blue pearl
Default 2012 WRX stage 1 logs (first time)
Hey everyone, just flashed stage 1 today, have about 30 miles on the stage 1 tune before doing these data logs, about 5900 miles on the car all together. All logs were taken during a 15-20 time frame, around 8:45pm. Using shell 93 octane gas.
Seems like I had some fine knock that learned itself away throughout the logs. During log 4 I had forgot to stop logging so I shifted into 4th and then 5th before realizing.
Looks like the boost may be on the low side. If you can take a look and tell me what you think id appreciate it. Hope everything is OK.
Is the boost low enough to warrant trying the high WG map? Do a few more logs first? Earlier in the day during live data highest boost was 16.1. Thanks in advance.
1)
https://docs.google.com/spreadsheet/...wQ2pFcUE#gid=0
2)
https://docs.google.com/spreadsheet/...WZXY3dmc#gid=0
3)
https://docs.google.com/spreadsheet/...5SFpqUXc#gid=0
4)
https://docs.google.com/spreadsheet/...KS2JlZmc#gid=0
nyrangerfan222 is offline   Reply With Quote
Old 08-08-2012, 11:01 PM   #2
BigRob74
Member#: 305107
2012 wrx
360/386 E85
i would try the hgw map but keep an eye on boost so you dont overboost. otherwise, the logs look good
BigRob74 is offline   Reply With Quote
Old 08-09-2012, 12:56 AM   #3
bacalhau16
Member#: 297565
2011 WRX hatch
+1 Logs look good. If you want to try the HWG map just do another log, then perhaps do a short log of where you might be going 100% in 4th or 5th gear to assure you wouldn't be overboosting.
bacalhau16 is offline   Reply With Quote
Old 08-09-2012, 10:15 AM   #4
Cobb Tuning
Member#: 4803
1)
2)
3)
4)
As others have stated, you can give the high wastegate map a try to improve boost/boost response. Take some additional logs if you do.
Bill
Old 08-09-2012, 12:55 PM   #5
nyrangerfan222
Member#: 308858
2014 wrx hatch
Plasma blue pearl
Thanks guys, other than the boost everything else was ok right.
Quick question, how much does humidity play a roll in boost levels? Reason i ask is because when these logs were taken it was 75% humidity, today is supposed to be around the same 75%-80% as well as for tomorrow. Should I wait till it drops some or it doesnt really matter? Thanks again.
Old 08-09-2012, 05:00 PM   #6
Cobb Tuning
Member#: 4803
Temperature can definitely have an impact on boost response. If you are switching to a high wastegate map in the summer, you would want to do some additional logging when it cools off just to make sure you are not then overboosting. But, generally, it is not a problem.
Bill
Old 08-21-2012, 02:31 PM   #7
Phillysubaru89
Member#: 328527
2009 impreza wrx
black
Could someone please review my logs and tell me if everything looks ok. 2009 stage 1 wrx
https://docs.google.com/spreadsheet/...HlocjlkbmpfU3c
Phillysubaru89 is offline   Reply With Quote
