Old 08-08-2012, 10:00 PM   #1
kuntryquest
Member#: 278027
2005 Legacy GT
Pearl
Default HELP!! Losing connection at OBDII port
Car
2005 Legacy GT limited
Front mount / 20g / supporting mods.
Took the car in for inspection today, the computer didn't come up with anything but error.
So I grab my blue point scanner when I get home and sure enough
It connects then 15 sec later it says its lost connection.
Pin 16 has 12.6v
Pin 5 has ground connection.
Ideas?
kuntryquest is offline   Reply With Quote
Old 08-08-2012, 10:54 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Power for that point comes from fuse SBF-5 under the hood and passes through the Main Relay. If the fuse is good the check the yel/red and yel/blu wires on the relay and see if they have voltage on them when the relay is turned on.
Old 08-09-2012, 04:09 PM   #3
08Legacy-GT
Member#: 325949
hold it up there, clip may be broken or bent see if that works
08Legacy-GT is offline   Reply With Quote
Old 08-14-2012, 02:51 PM   #4
kuntryquest
Member#: 278027
2005 Legacy GT
Pearl
Update :
Pulled the plug off the housing and pushed all the pins back in, held the connections toghther and it passed.
Old 08-15-2012, 10:46 AM   #5
TXwrxWagon
Member#: 191557
2004 WRX Wagon
WRB not so minty fresh
that's what mine was doing. the pins were pushing out the back.
Rob
TXwrxWagon is offline   Reply With Quote
