Old 02-07-2013, 11:53 PM   #26
Danomite
Member#: 190449
2008 RAW motor/Ah2nD
I wish I would have known about this when I was having issues with my new built motor 3 years ago and my builder was blaming everything but the motor. It was the cams were too big for the turbo or I needed a standalone ecu. But he did replace the cams at no charge eventually.
Danomite is offline   Reply With Quote
Old 02-08-2013, 03:51 PM   #27
climbhigh09
Member#: 254163
2011 WRX 20GXTR
^ this thread +your problem=no relation.
climbhigh09 is offline   Reply With Quote
Old 06-13-2013, 03:41 PM   #28
torbaru88
Member#: 359380
TO OP: At what RPM were you experiencing the misfire? I think I may have to purchase this manifold now. My misfire is at 2000-2400 rpm. PM price/availability.
Thank you
torbaru88 is offline   Reply With Quote
Old 06-13-2013, 04:16 PM   #29
Paidfor
Member#: 267815
Be in awe
dont hate .)
Thats one hell of a CNCd bandaid lol
Watever works tho .)
Paidfor is offline   Reply With Quote
Old 06-28-2013, 07:00 PM   #30
OctaneMatt
Member#: 360764
We have a Cosworth 2.6L longblock that we will be firing up soon and the cam issues are a big concern. It was built mid or late last year. Is there an easy way to check for these issues (offset wheel, misplaced oil passage) now that the engine in the car?? Also, are the billet solenoid blocks available for purchase?
Thanks,
Matt
OctaneMatt is offline   Reply With Quote
Old 03-11-2014, 06:42 PM   #31
OctaneMatt
Member#: 360764
Are these block available?
Old 03-11-2014, 10:43 PM   #32
pet3r
Member#: 283134
2008 STi AW
550whp - 530wtq
Pretty awesome troubleshooting and execution. My only question is why wouldn't the cam manufacturers send you new cams that were drilled properly? Was it just to get the car up and running, or for the fun of being a freaking awesome shop showing off to the subienet?
pet3r is offline   Reply With Quote
Old 03-12-2014, 05:41 AM   #33
tomacGTi
Member#: 297396
Because unless you've ever installed cams in a Subaru, you will not know how they are a PIA to do in the car.
You will explore every option to not have to pull the motor again, remove cams again, remove cam gears again replace seals again, reshim again and then reinstall. Not to mention downtime and actual time for the job and the potential for something to go wrong during the pull/reinstallation.
They had the means, tools and technology to fix a complete FUBAR without pulling the the motor. I would do the same if I had the same options offered to me.
tomacGTi is offline   Reply With Quote
Old 03-12-2014, 12:47 PM   #34
OctaneMatt
Member#: 360764
We have suspect engine that is not running (still needs to be wired). Is there a simple way to check for bad cams without tearing it apart? I'm thinking it should be possible to pressurize a feed line and see which way the exhaust cam turns. Any tips? Thanks!
Old 03-23-2014, 07:12 AM   #35
maverick83
Member#: 309577
Default Tomei Poncams
Hi guys, we have just installed a Tomei poncam dual avcs kit on a 2011 STI and the nightmare began...
Exhaust side working properly.
Intake side completely stuck,right side always at zero degrees, left side always staying around 10/12 degrees even at idle,full load etc.
We have checked everything. Wirings,ECU,even simulate a current to the actuators... And here came the possible confirmation : when you put a current on right side the cam sensor gives an advance of 40 degrees and then comes back to zero.
On left side it goes to almost 60 degrees and then comes back again to 10/12 degrees.
So... Only on left intake shaft either the phase pin is wrong or the trigger marks read by the cam sensor are wrong!
Can you confirm that this difference between left side and right side could Shut all intake avcs part?
Very disappointed so far... I've already contacted Tomei and I'm waiting an answer soon.
maverick83 is offline   Reply With Quote
Old 03-23-2014, 11:24 AM   #36
Flat 4 Motorsport
Member#: 295846
WRX FP HTA GT3076R
Sexual Chocolate
^^ I had a similar problem on a set of DAVCS Tomei Poncams on a customers car.
now after reading this thread, I'm 100% positive this was the problem. they would go go to full retard position as soon as the car would start and not zero themselves.
couldn't figure out the problem and ultimately swapped them for a set of Kelfords, after checking the build date the Kelfords were updated build date.
FWIW, I always use GSC cams. Never had an issue. Only reason Kelfords were used is they were availbale right away.
-Phil
Flat 4 Motorsport is offline   Reply With Quote
Old 03-23-2014, 07:53 PM   #37
maverick83
Member#: 309577
Have you already called Tomei in order to complain?
If they get several feedback maybe they will resolve quicker...
Old 03-31-2014, 03:54 PM   #38
mboulton
Member#: 174433
what is the build date for the Kelfords that suggest they are okay? vs a defective build date I assume?
mboulton is offline   Reply With Quote
Old 06-30-2014, 07:12 PM   #39
awenthol
Member#: 355024
2013 DGM STi Sedan
I just bought Kelfords about 2 months ago. AVCS holes are drilled correctly.
awenthol is offline   Reply With Quote
Old 07-10-2014, 12:55 PM   #40
evasabzacami
Member#: 382795
Default Tomei Poncam Dual AVCS problem
Hi everyone from Russia.
I got the same problem with Tomei Poncam Dual AVCS set (260 degrees 9.8mm lift on the intake and 258 degrees 10.80mm lift on the exhaust).
The exhaust side was okay, on the intake - the right cam was offset by around 10 degrees, and the AVCS wouldn't work. We checked everything possible after there was nothing left but to take the engine off.
We found that one marker on the right intake cam was offset by around 1mm. So the ECU was confused as it got contantly different data from the markers.
We contacted Tomei last week and still waiting for their response.
So guys, check the cam markers to be identically spaced (around 18.45mm) before buying them.
This defect has caused me 2 months and around USD 2k:-(
evasabzacami is offline   Reply With Quote
Old 11-05-2014, 08:18 AM   #41
jockeygolfs
Member#: 260868
2011 STI
Are the pictures still available? I can't seem to see them on my computer. I just bought cams an want to confirm that they are right.
jockeygolfs is offline   Reply With Quote
