#1 |
Member#: 282166
i dont know what is going on with my car! my first day data logging with my friend and he said my numbers are very odd. my car feels nothing like his and we have very similar mods. car is a 2002 wrx. catless turboback, cobb stage 2 ACN1 91, and a aem short ram.
#2 |
Member#: 321571
TXIC
Vehicle:2012 WRX Base Ice Silver |
Post the data log so folks can take a look at it. You can use google docs to do this, just make sure to change permission from private to public.
#3 |
Member#: 287023
Vehicle:2011 WRX Base Hatch Obsidian Black Pearl |
It looks to me like there is something wrong with your air/fuel ratios. Cobb is usually on here in the mornings and may be able to help more but it looks to me like you need to try a different map or have some major modifications done to your current one.
#4 | |
NASIOC Manufacturer
Member#: 4803
You could have other mechanical issues as well, but for now I would not do anything (and no more WOT or heavy throttle runs) until you get the stock or Cobb SF intake installed. When you do, reset the ECU via the troubleshooting menu on the AccessPORT and then drive through about a tank of gas and check your A/F Learning 1 A, B, C, and D values again. They should generally be within +/- 5%. If you still have a problem then, you might have another issue such as intake tract leak, bad MAF or bad front o2. Bill |
#5 | |
Member#: 282166
so before i even checked this thread again i put the stock intake back in and resetted the ecu. car feels much better and looks like better numbers but still not hitting full boost. ![]() |
#6 |
Member#: 282166
stage 2 hwg map
#7 |
Member#: 287023
That's a step in the right direction from before.
#8 |
NASIOC Manufacturer
Member#: 4803
If these logs are with the stock intake after ECU reset, you still have a problem with fueling. Your "C" range A/F Learning 1 is rapidly increasing and the last log show it at 7%. I would keep driving to see where they end up. There may still be a problem that you need to address (such as an intake tract leak, bad MAF or bad front o2). I would do that before trying to solve the low boost issue.
Bill |
#9 | |
Member#: 282166
#10 | |
NASIOC Manufacturer
Member#: 4803
Bill |
#11 | |
Member#: 282166
should i reset ecu and reflash and then run through a tank of gas? |
#12 | |
NASIOC Manufacturer
Member#: 4803
Bill |
#13 | |
Member#: 282166
will do so and i will update you with a data log once i've done so. |
#14 |
Member#: 282166
![]() after a tank of gas |
#15 |
Member#: 316415
Vehicle:2006 WRX WRB |
Hmmm, got sum knock again. Based on your MAF seeming relatively low through the higher rpms I'd reccommend cleaning the MAF. See how that goes and try again.
#16 |
NASIOC Manufacturer
Member#: 4803
Your DAM has dropped which is an indication of knock. Your long-term fuel trims for "C" is still a problem.
Try swapping out your MAF sensor with your friends temporarily, reset the ECU (via the troubleshooting menu on AP) and do the same WOT run as the last log. We can then compare the peak mass airflow and see if it is noticeably higher than your previous log. If so, then the MAF sensor is the likely cause of your issues. If that is the case, you can try cleaning yours and if that doesn't work, you may have to get a new one. Besides the MAF sensor, the two other most common issues that can cause extreme fuel trims are post-MAF intake tract leaks (do a pressure/smoke test of intake tract to be sure) and bad front o2. Bill |
