Old 08-10-2012, 01:48 AM   #1
Boxerscoopy90
Member#: 309974
Default Uel header question
Finally i got my ebay uel header for my 07 impreza and im installing it in a couple of days i have decided that i wouldnt wrap it ir even having a thermal coating . However i've read that the more heat the header would create under the engine bay could make things go bad or melt i dont remember . My questin is what are the things that i have to worry about because of the excess heat that the header would create
Boxerscoopy90 is offline   Reply With Quote
Old 08-10-2012, 02:20 AM   #2
klaus_b2
Member#: 318411
17 WRX
CWP
the header probably wont even bolt up
klaus_b2 is offline   Reply With Quote
Old 08-10-2012, 02:22 AM   #3
Bababou
Member#: 280689
2010 2.5i Impreza
Newport blue
From what I have seen your better off using a hightemp header paint but not header wrap. The wrap will actually make the header rot out. Also Im guessing you know that there are multiple things to mod to make a header from Ebay work on your car.
Bababou is offline   Reply With Quote
Old 08-10-2012, 02:42 AM   #4
Bababou
Member#: 280689
2010 2.5i Impreza
Newport blue
Not true, it will bolt up just kicks out on the wrong side to match up to anything else.
Old 08-10-2012, 10:32 AM   #5
20g07wrx254
Member#: 306217
2007 wrx
white
They are right. Ebay **** very very very seldom will be a direct fit for ANY car. Gotta be careful with eBay most of the **** on there is junk anyways. Spend the extra $ and get a decent part. Doesnt even have to be top of the line
20g07wrx254 is offline   Reply With Quote
Old 08-10-2012, 11:27 AM   #6
tludwins539
Member#: 149764
2007 2.5i
Borla Replica Ebay headers have been the preference for many 06/07 NA UEL headers. More people talk about the borlas cracking and other problems.
I have had borlas on my car for ~60k miles without anything melting or any other issues after the initial issues with the o2 sensor extensions and relocation.
tludwins539 is offline   Reply With Quote
Old 08-10-2012, 02:07 PM   #7
20g07wrx254
Member#: 306217
2007 wrx
white
Its hit or miss with ebay
Old 08-10-2012, 03:04 PM   #8
Boxerscoopy90
Member#: 309974
Fitment shouldn't be a problem and i know about this . But i know nothing about that high temp header paint do u think its a good idea ?! And btw what if it cracks by the time would i end up just getting another one or there is a solution dor these cracks
Old 08-11-2012, 01:49 AM   #9
Bababou
Member#: 280689
2010 2.5i Impreza
Newport blue
The header paint is to keep it from rusting, its not going to retain much if any heat but its cheap insurance aginst rotting out. If you use it just make sure you follow the curing process on the can, its a set of heat cycles. If it cracks an exhaust shop should be able to weld it for you cheaper then a replacement.
Old 08-12-2012, 02:17 PM   #10
Boxerscoopy90
Member#: 309974
Got it thx for clarifying
Old 08-22-2012, 05:53 PM   #11
Garbels90
Member#: 322129
2007 Impreza SE
Newport Blue
I need help. I have a question about UEL headers making my nonturbo impreza sound nicer. I see people on youtube that have done it to their non turbo imprezas and it almost sounds almost like a wrx. im not trying to get that turbo sound, im just trying to get that nice subaru rumble that the wrxs have.
Professionals say its not possible but like i said earlier other people have put Uel headers and an intake on their non turbos and it sounds much much better, anyone have any info? Because i dont want to go ahead and buy all the parts only to find out it doesnt work. thanks
-Dylan
Garbels90 is offline   Reply With Quote
Old 08-22-2012, 06:00 PM   #12
Bababou
Member#: 280689
2010 2.5i Impreza
Newport blue
Use the search option it does wonders. You have two options. What this guy is doing, pre 06 header and replace everything back from there or the rallisport racing header. Go forth and search on. Yes they either one will work, pick what you prefer to do.
Old 08-22-2012, 06:16 PM   #13
klaus_b2
Member#: 318411
17 WRX
CWP
-Dylan
follow my thread if you want...im doing the borla setup. and be ready to spend some cash lol
Old 08-22-2012, 06:40 PM   #14
spazsubaru
Member#: 273127
2007 impreza 2.5i
mine just got installed today. they needed a 90 degree angle for it to bolt up to my apex n1. reallllly loud subie rumble
spazsubaru is offline   Reply With Quote
