Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 08-10-2012, 06:55 PM   #1
Engelkes92
Member#: 304370
2007 Impreza
Default Cobb stage 2
So this weekend I will have my catted downpipe to finish off my tbe. I was wondering if the Cobb stage 2 91 map was just meant to hold you over till you can get a pro tune or if I can run on it indefinitely or till I choose to get a pro tune? Also, it's an invidia n1 racing cat back and invidia catted downpipe
Engelkes92 is offline   Reply With Quote
Old 08-10-2012, 09:42 PM   #2
hutch959
Member#: 267463
i think its a good start. log and see what you got.
hutch959 is offline   Reply With Quote
Old 08-11-2012, 10:41 AM   #3
bacalhau16
Member#: 297565
2011 WRX hatch
You can run the stage 2 Ots map indefinitely. Many people do. Others have found gains with going with an email tune. Then Ofcourse you could always get pro tuned which typically yields the best results.
bacalhau16 is offline   Reply With Quote
Old 08-11-2012, 11:57 AM   #4
Cobb Tuning
Member#: 4803
The OTS maps are designed to be safe enough to be run on the vast majority of cars long-term, as long as your modifications are compatible with the map in question (ex. correct intake). You can view the map notes for an individual map in the maps section at cobbtuning.com to see what is required for a map. If you have an AccessPORT version 2, you can also get a data log to see how well the map is performing (check out our data logging video below).
A protune, while not necessary, will generally give you gains in performance and potentially driveability as it is designed for your specific car and your local fuel quality/conditions.
Bill
