Old 08-10-2012, 07:37 PM   #1
Wirk
Member#: 296043
2006 WRX
Default Strange Parking light issue 02 wrx
So the other day I got pulled over cause my Parkin lights weren't on, I didnt even realize this so he let me go on my way. I found a blown fuse, replaced it and they worked. Today there was smoke coming from behind the steering wheel and the lights were out. I took the column apart and found that the wires going to that parking light switch on top of the console were hot and the cause of the smoke. I unplugged the connector an no more heat or smoke. It appears the wires just go to that switch and don't continue anywhere else.
Anyone have any ideas what this could be? I guess theres a problem with the switch but im not sure. The lights still don't come on. I checked the fuse and it's not blown. The lights do flash when I arm or disarm the alarm.
I never use that switch so I don't really care if it works or not. I guess the easy thing to try would be a different switch but I'll have to order one an I need my car drive able.
Any thought or suggestions are very much appreciated.
Wirk is offline   Reply With Quote
Old 08-10-2012, 11:46 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Power for the lights passes through that switch even if it isn't turned on. If just the switch is bad the wires should be burned near the switch due to excessive heat from the bad switch. If the wires burned beyond the switch area then it seems that excessive current caused the damage and the fuse didn't blow out like it should have. Hopefully you have the correct fuse in place. I think it is supposed to be 15 amps but I'm not sure of that.
Cougar4 is online now   Reply With Quote
Old 08-11-2012, 01:43 AM   #3
Wirk
Member#: 296043
2006 WRX
I was kinda thinking that might be the case, thanks for the input.
