Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 08-10-2012, 08:59 PM   #1
Blubullt02
Member#: 221344
2002 impreza wrx
wrx rally blue
Default sbd5 fuse. help
Ok so I have a 02 wrx with built motor and just about every bolt on. I had a wideband sensor welded in yesterday and drove home. This morning I started it up and got halfway down the driveway and it stopped. It turned over but I couldn't hear the fuel pump priming. Found that the sbf5 fuse is blown. Researched on here and started unplugging thing such as the fuel pump, relay fuel pressure controller, 02 sensors, all engine sensors, and the Ecu. Tested the relays and pump, all ok. Found that the voltage/amps drop where the fuse plugs in when I unplug the bottom plug if the ecu plugs are facing the 3oclock position. I am now stuck. I plugged in another Ecu and it doesn't fix the problem. I have all of the carpet and seats ripped out and.I traced all the wires inside and none have damage. What would the next step be? Thanks.
Blubullt02 is offline   Reply With Quote
Old 08-11-2012, 12:40 AM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
That fuse also supplies power to a lot of engine sensors including the O2 sensors. Chances are that one of those sensor wires has made contact with the exhaust system and burned through the insulation causing a short. Check over the wires on the engine carefully and you will most likely find the trouble spot.
Cougar4 is online now   Reply With Quote
Old 08-11-2012, 10:24 PM   #3
Blubullt02
Member#: 221344
2002 impreza wrx
wrx rally blue
Ok so it turns out that there was a rat living under my back seat and it chewed the wires going from the fuel pump pressure controller to the fuel pump under the car above the gas tank. It was shorting. Thanks for the help!
Old 08-12-2012, 12:31 PM   #4
Cougar4
Member#: 53443
Winestone
Well that wasn't what I was expecting to be causing the trouble but stuff happens. Thanks for the update and glad you found the trouble.
