Old 04-14-2014, 10:11 PM   #101
bjohnson_55
Member#: 216580
Originally Posted by Zee Biker View Post
When you say more than 1000cc's, do you mean at stock base pressure?
Peak torque at 4500 meaning peak boost right around there as well? Was that a stock 2.5 motor or a built something?
Pretty exciting to hear the WHP possibilities!
ID1000's at 60psi base and walbro 400 hardwired not even close even with tapered boost. Still high 90's% idc.
Boost right before pk tq. Avcs was pretty dialed in. Fully built motor. Cnc heads. Bc272 cams.
It's a stout street turbo. Wideeeee powerband.
bjohnson_55 is offline   Reply With Quote
Old 04-15-2014, 10:06 AM   #102
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
Peak boost is usually 2-300 rpm before peak torque, no?
Subian is offline   Reply With Quote
Old 04-15-2014, 03:11 PM   #103
BroBroBroBroBro
Member#: 338211
2011 wrx cobb 20G
Originally Posted by Dutch Devotion View Post
And what makes you get a boner is response and crispyness (don't know another word for that feeling).
The word is orgasm, cause when ur having sex with a hot girl and the feeling you get when ur about to finish and you pull out.
thats the feeling of subaru.
BroBroBroBroBro is offline   Reply With Quote
Old 05-01-2014, 09:54 AM   #104
BoostHard
Member#: 235550
2007 WRX TR
Originally Posted by ppayer38 View Post
I bet it performs better than the old 68HTA and if you could get the bigger compressor housing it would help a great deal. 8cm hotside is plenty for out cars...
I have an 8cm hotside on my evo 3 16g and i can honestly say that it could benefit from a 10cm.
BoostHard is offline   Reply With Quote
Old 06-16-2014, 01:38 PM   #105
mofoSTI
Member#: 236252
08 STi
Originally Posted by 907Bum View Post
Decent turbo, tuned a couple of them. I would recommend staying away from FP as their customer service has burned a couple of my customers. Their turbos are decent, just terrible customer service.
Full boost at 4500 feet 3600rpms (2.5l 3rd 5speed) 91oct, 340hp mustang
Full boost at 4500 feet 3450rpms (2.5l 3rd 5speed) E85, 410hp mustang
turbo is similar to a dom1.5
Do you have any dyno comparisons between the hta68 and hta71? I have yet to see anybody running the hta71 on an STi.
mofoSTI is offline   Reply With Quote
Old 06-17-2014, 05:48 PM   #106
bulldog2277
Member#: 157924
1977 Trans Am
98 Rs
I just purchased an FP hta71...
Its currently being installed by Squidz (along with a low-mileage Rally Sport Direct block and some other goodies)
Should have the car tuned by Cobb Plano on Saturday (6-21).
I will post dyno graph and mods early next week - hoping to hit around 375whp on 93 oct
bulldog2277 is offline   Reply With Quote
Old 06-20-2014, 01:50 PM   #107
mofoSTI
Member#: 236252
08 STi
Well?
Old 06-20-2014, 02:36 PM   #108
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
Originally Posted by mofoSTI View Post
Well?
Well what? He said tuned 6/21. That's the future. It's a Subaru not a Delorean.
ProfessWRX is offline   Reply With Quote
Old 06-20-2014, 02:40 PM   #109
beaumier2006
Member#: 300758
2008 WRX
Red-ish
^^^ Lmfao
beaumier2006 is offline   Reply With Quote
Old 06-20-2014, 05:16 PM   #110
mofoSTI
Member#: 236252
08 STi
Well?
Old 06-20-2014, 06:40 PM   #111
bulldog2277
Member#: 157924
1977 Trans Am
98 Rs
Well?
Don't have the 1.21 gigawatts neccesary to power the flux capacitor
Old 06-20-2014, 07:07 PM   #112
mofoSTI
Member#: 236252
08 STi
That's OK. Just bypass the third rail and run a jumper over the core under the lower flange. That will double gross wattage no problem. I'm just impatient
Old 06-22-2014, 12:02 AM   #113
bulldog2277
Member#: 157924
1977 Trans Am
98 Rs
Ended up with 356whp/384wtq. Will need to wait until Monday to post dyno graph. It was about 20 short on torque and whp than I was wanting. But the power band is amazing
Old 06-22-2014, 12:24 AM   #114
alexandern05
Member#: 266954
04 wrx v7 sti swap
agile tuned 389hp 342ftlb
On 93? My hta68 woke up on Meth and high boost.
alexandern05 is offline   Reply With Quote
Old 06-22-2014, 01:26 AM   #115
mofoSTI
Member#: 236252
08 STi
On 92 oct at 20 psi I made 345whp 340 lb ft of torque. Way less than I was thinking I would make.
Old 06-22-2014, 06:05 AM   #116
bulldog2277
Member#: 157924
1977 Trans Am
98 Rs
Cobb Plano said doing E85 would give me a substantial increase.
I may do it at a later time, would just need to get a bigger fuel pump.
Old 06-22-2014, 06:08 AM   #117
bulldog2277
Member#: 157924
1977 Trans Am
98 Rs
Mines running at 24 psi. I expected more power too, but the power band is fantastic. It really feels like factory spool
Old 06-23-2014, 10:47 AM   #118
Squidz
Member#: 142608
2003 Sonic Yellow
Marginally well behaved.
The Spool on Bulldog's car is awesome for the power it makes.
These turbos were really built for E85 it seems. Most people have been dissapointed with the 'numbers' on pump. However, while the peak numbers may not be there on pump gas...the power under the curve is still very impressive and ultimately makes for a faster car.
Squidz is online now   Reply With Quote
Old 06-24-2014, 11:03 AM   #119
bulldog2277
Member#: 157924
1977 Trans Am
98 Rs
Here is the Dyno Sheet
Old 06-30-2014, 07:14 PM   #120
mofoSTI
Member#: 236252
08 STi
I agree. This turbo spools so early it almost feels like a na car. Pulls to 7200 no problem with no big surge of power. It doesn't feel that much if any faster than stage 2 to me. I was running Cobb intake with cold air box, Perrin DP, vibrant 3" cat back with no muffler and Cobb ap running 91acn map. I run 92oct shell or cheveron gas. My new tune is rough so I'm going to run a different fpr and Perrin headers and go back for a retune. I hope that helps some.
Old 06-30-2014, 11:11 PM   #121
04fpgreensti
Member#: 151655
2007 Legacy GT
Originally Posted by WhatTurboLag? View Post
I still wana hear it!!! Lol
Put an intake and blow off valve on your car and go floor it... you'll hear it I promise
04fpgreensti is offline   Reply With Quote
Old 09-18-2014, 11:00 PM   #122
Renagade187
Member#: 145427
2014 Impreza WRX STI
WR Blue
to bring this back from the dead...
could you provide a FULL mod list when this was done.
Would be apreciated, as I am considering doing this build.
Also good to know Cobb Plano did it!
Renagade187 is offline   Reply With Quote
Old 09-23-2014, 01:25 PM   #123
bmxhotsauce
Member#: 127099
02 IMPERZA WRX
BLACK
any one have a new HTA 71 red dyno graph on E85? im thinking of purchasing one. from the last graph it looks like the spools is great.
bmxhotsauce is online now   Reply With Quote
Old 09-23-2014, 04:08 PM   #124
SubaruDood
Member#: 340058
Has anyone considered the steamspeed line of turbos? I think the one they make that would be closest matched to that HTA 71 is the Steam STX 71. From what I'm reading, based on others' reviews, it spools early and fast. It doesn't seem to run out of air either in the top end. Someone pulled 452 whp on e85 and found they had an uppipe leak afterwards! Just google Steam STX 71.
SubaruDood is offline   Reply With Quote
Old 09-23-2014, 05:33 PM   #125
Squidz
Member#: 142608
2003 Sonic Yellow
Were you wanting the mod list for my car (the wrx posted in the beginning of the thread) or Bulldogs car (the STi posted above)? I can get you either one.
Cobb Plano tuned both Bulldogs and my car. (and did an incredible job, I might add)
I built them both however.
