Old 08-11-2012, 09:19 AM   #1
JDMFLCL
Member#: 180513
Baby Baby C'mon!
Looka Bomba! 99 JDM GM8
Default Which GMS radiator works?
1999 2.5rs with EJ20G (1995)
Do i get the one without the rad. cap or the one with? I'm currently running a stock RS radiator with the jdm coolant tank
Thanks for your time.
JDMFLCL is offline   Reply With Quote
Old 08-11-2012, 11:08 PM   #2
JDMFLCL
Member#: 180513
Baby Baby C'mon!
bump.
Old 08-12-2012, 11:37 AM   #3
JDMFLCL
Member#: 180513
Baby Baby C'mon!
I guess more specifically - Can I run the 93-98 GMS radiator as opposed to the GMS swap radiator? I really want to retain factory fans.
Old 08-12-2012, 11:50 AM   #4
beaviscih
Member#: 123362
'93 Crapcan, '98L
Sold, '04 STi - Sold
I looked at these but went with the stock dimension Koyo. While I liked the potential cooling benefits of the GMS it wouldn't clear my GT Spec Header (passenger side). If you are using an aftermarket header, you may want to double check fitment.
Specific to your question, I believe either would work (with or without a filler neck). Personally I like the filler neck even though you have to cut the radiator cap; makes burping the system easier. As for the stoker Koyo I never had a cooling issue while living in Texas.
beaviscih is offline   Reply With Quote
Old 08-12-2012, 11:58 AM   #5
JDMFLCL
Member#: 180513
Baby Baby C'mon!
I do have Gruppe-S headers. I once test fitted an Ebay radiator (which i presume is almost identical in size) and the radiator had no issues clearing the headers.
I presume the 93-98 GC8 radiator isn't quite as thick as the swap one? Not being able to use the stock fans (granted I'd be willing to shave the shrouds) is a deal breaker for me.
Old 08-12-2012, 03:28 PM   #6
sti_95imp
Member#: 53774
1995 Impreza
Dirty.
Just use your stock radiator. I have a '95 L model with a EJ20G and used my stock radiator for 2 years. The only reason I changed it was because it cracked. And my car was used for racing almost exclusively.
Stock radiators work just fine. Don't let anyone tell you different.
sti_95imp is offline   Reply With Quote
Old 08-12-2012, 10:22 PM   #7
JDMFLCL
Member#: 180513
Baby Baby C'mon!
For track days?
Old 08-14-2012, 01:53 PM   #8
Bookem74
Member#: 174481
98 Legacy GT-T
Originally Posted by JDMFLCL View Post
Not being able to use the stock fans is a deal breaker for me.
Is there a particular reason for needing the stock fans? Is it price of slim fans?
I have two good 10" spal I'd sell fairly cheap, I probably have ends I could wire in and be plug and play for you.
Bookem74 is offline   Reply With Quote
Old 08-14-2012, 08:46 PM   #9
sti_95imp
Member#: 53774
1995 Impreza
Dirty.
For track days?
Almost exclusively rallycross. High revs, low speed, and high ambient temps. Never had an overheating issue. Even the day it cracked, it didn't get hot. I would stay stock until you see a need for upgrade.
Old 08-15-2012, 02:01 AM   #10
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Do run the thermostat?
i_c_the_light is offline   Reply With Quote
