South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 08-12-2012, 11:00 AM   #1
04reddragon
Member#: 216553
2006 wrx sti
gray
Default vf39 no tune
Well im thinking my stock turbo on my 04 is shot its leaking oil when first tuned it was pushung 16.5 psi no leaks at all now its at 9 psi i inspected the turbo no shaft play at all just oil. Now my question is can i put on my vf39 on with out a tune? Im currently stage 2 also no injectors yet or fuel pump for the upgrade
04reddragon is offline   Reply With Quote
Old 08-12-2012, 01:53 PM   #2
brocksdad
Member#: 107352
Not Respectable
You can, but it's not a good idea at all.
brocksdad is offline   Reply With Quote
Old 08-12-2012, 06:29 PM   #3
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Are you certain it's the turbo? Perhaps the car is actually in limp mode or something in your boost control system is broken.
Old 08-12-2012, 09:48 PM   #4
04reddragon
Member#: 216553
2006 wrx sti
gray
Im not sure at all the whole time i thought it was but did a boost leak and no leaks at all how woild i know im on limp mode? Even when phoung tuned me at 16.5 psi then it dropped to 12 then barley hitting 9 thats why i think ita the turbo
Old 08-12-2012, 09:53 PM   #5
Chaz2.5
Member#: 168181
1999 EJ205 RS coupe
No! Don't put it on.
Chaz2.5 is offline   Reply With Quote
Old 08-12-2012, 10:41 PM   #6
brocksdad
Member#: 107352
Not Respectable
Reset the ECU and see if the boost goes back to normal. If it does, you were in limp mode. It will only be a matter of time until the IAM drops back down and lowers the boost again.
Old 08-12-2012, 11:09 PM   #7
04reddragon
Member#: 216553
2006 wrx sti
gray
Yea man i did that after i install a catless uppipe and no go same issue when i took it to u for the boost leak and it was fine so i think its the turbo but the turbo looked fine :/ wat else can i do?
Old 08-13-2012, 12:09 AM   #8
cronic
Member#: 9749
Did you just install this uppipe when this started happening?
cronic is offline   Reply With Quote
Old 08-13-2012, 12:15 AM   #9
04reddragon
Member#: 216553
2006 wrx sti
gray
no it happened maybe 6-8 months ago roughly just sucks that i cant get full boost like it was before so i posted this up hoping someone knows what i can do.
