Welcome to the North American Subaru Impreza Owners Club Saturday October 22, 2016
Old 08-12-2012, 02:54 PM   #1
Member#: 250706
2004 Impreza WRX
Default Target boost and AFR?
I have had a few threads lately about target boost after stage II flash and what could actually be adjusted etc. I went back and read the notes for the version 1 AP's stage II, which is peak at 16.5 give or take 0.7 psi. I have an adjustable bov setup 50/50. I had to play with it when I got it to get the stock setup and maps to go back to hitting target stock peak boost.
So I have fiddled with it on my stage II map, for the version 1 AP, and have gotten it to 15.8-16 psi with my AFR being 10.5ish at wot pull in 3rd gear. Is that AFR sound correct for a 3rd gear pull? I ask because I have the torque pro app for my phone and a bluetooth dongle, and it monitors a couple things. These were the readings I got last night on the way home and was curious if those two sound right together? Remember this reads my stock o2, and not a wideband, but it isnt a ****ty afr gauge, it reads it directly from the ecu.
peak boost at 16 psi with an AFR of 10.5 at the lowest during 3rd gear wot pull....sound right?
Trudd84 is offline   Reply With Quote
Old 08-14-2012, 07:14 AM   #2
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
The stock O2 sensor is less than useless while in boost conditions. Mine would peg at 11.1:1 when my car was actually running ~10:1. If you plan to do any real tuning, get a wideband and ditch the ever so useless V1 accessport.
If not, just leave it alone... Because you can't really accurately do a damn thing right now.
Black94Snake is offline   Reply With Quote
