Old 09-03-2002, 03:12 PM   #1
42202sub
Member#: 17080
2002 WRX, Silver
AWHP ?? [email protected]
Question has anyone had this problem?
I have the Vishnu Stage 0.
When I get on it, it throws a CEL!
When i pull the codes, it is the same codes..301,302,303 and 304
Missfire in all 4 cylinders
has anyone got all of these codes @ once?
Could it be the piggyback ECU throwing these codes?
Could my sparkplugs need regapped?
Is it normal to get the 4 missfires?
Help Please!
Thanx:
Jimmy
42202sub is offline   Reply With Quote
Old 09-03-2002, 04:28 PM   #2
larryg
Member#: 13911
2002 Maxima
Someone in the MWIC forum has the same problem and I don't think he has the Vishnu...
larryg is offline   Reply With Quote
Old 09-03-2002, 04:40 PM   #3
codean
Member#: 10186
It could be that the colder plugs that you installed are fouled.
codean is offline   Reply With Quote
Old 09-03-2002, 09:26 PM   #4
Austin
Member#: 7089
2016 STi
Default Re: has anyone had this problem?
Yes. Unless you're feeling actual misfires, it's the unichip. The unichip alters ignition advance by intercepting and changine the crank angle signal. The stock ecu compares the crank angle signal and the cam angle signal to determine a misfire. With the altered crank angle signal, there is now too much difference between the two, and the stock ecu thinks you're misfiring.
Austin is offline   Reply With Quote
has anyone had this problem before? superblkwrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 04-22-2007 12:30 PM
Has anyone had any problems with the cobb Stage 2 kit? Subarubrim Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 32 03-08-2005 05:20 PM
has anyone had tranny problems with their new wrx scooby Newbies & FAQs 1 12-07-2001 10:47 AM
Has anyone had rust problems with SPO Motorsports Adjustable Rear Sway Bar Kit? Sean Brakes, Steering & Suspension 2 08-20-2001 08:55 AM
Has anyone had reliability problems turbo? SpeedKills Normally Aspirated Powertrain 6 10-28-2000 12:11 AM
