Welcome to the North American Subaru Impreza Owners Club Thursday January 29, 2015
Old 08-13-2012, 05:52 PM   #1
sja21191
Member#: 314687
2006 STi
Default Hybrid build ?'s, help needed
I'm currently in the process of putting my hybrid motor together. I have a 2011 STi block and 2002 WRX heads. I'm getting the heads smoothed out so I can run the STi head gasket. So my question is, which car do I buy the complete gasket set for? Id like to get it ordered tonight, so help is appreciated!! Thanks!
sja21191 is offline   Reply With Quote
Old 08-13-2012, 06:14 PM   #2
04ScoobyWtf
Member#: 287974
Ej25 get the oem gasket kit
04ScoobyWtf is offline   Reply With Quote
Old 08-13-2012, 06:15 PM   #3
sja21191
Member#: 314687
2006 STi
That's what I plan on doing, but there's an 04-06 kit, 07 kit and 2011-2012 kit.
Old 08-13-2012, 07:02 PM   #4
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
None of those kits will give you the cam seals and valve cover gaskets you need since your heads are 2002 non AVCS heads.
Old 08-13-2012, 07:51 PM   #5
sube-trex
Member#: 97577
Bug In Your
Eye
You aren't doing research. Less than 5 seconds.http://http://forums.nasioc.com/foru....php?t=1431376
sube-trex is offline   Reply With Quote
Old 08-13-2012, 08:31 PM   #6
03SubyWRX
Member#: 200767
2003 WRX 2.5 Hybrid
97 OBS pimp wagon
There isn't one gasket set that will cover your build. You can use a 2.5L gasket kit, but as mentioned you'll need cam seals and valve cover gaskets for 2.0L heads.
03SubyWRX is offline   Reply With Quote
Old 08-13-2012, 08:38 PM   #7
sja21191
Member#: 314687
2006 STi
I did try searching, but my question was simply because it is a 2011 block. I could only find information on the later model blocks. I also tried doing research to see of there was any noted differences online and the only thing I came up with was the air pump for cold emissions and nitrated crank shaft. Thanks for all the input
Old 08-14-2012, 10:49 AM   #8
luciferMotorCade
Member#: 253611
2004 GeNOME
News hybrid gasket kit.
standard 2.0l wrx kit with sti gaskets. Preracing.com can do this for $300. They are local to me and always done good business with me . shoot them an email and see what shipping would be to you.
luciferMotorCade is offline   Reply With Quote
Old 08-14-2012, 03:03 PM   #9
danger1138
Member#: 279525
04 rex luger!
Flatirontuning.com is where to go.
danger1138 is online now   Reply With Quote
Old 08-14-2012, 03:19 PM   #10
sja21191
Member#: 314687
2006 STi
^^ Yeah they're who I was looking into. But I'm also a dealer so I get 20% off at Subaru so I might save more going through them.
Old 08-14-2012, 05:36 PM   #11
luciferMotorCade
Member#: 253611
2004 GeNOME
Default numbers
I wanna say flat irons was expensive . lets us know how the dealer treats you .
Old 08-14-2012, 05:52 PM   #12
danger1138
Member#: 279525
04 rex luger!
U cant go wrong with oem
Old 08-18-2012, 02:21 PM   #13
sja21191
Member#: 314687
2006 STi
Ended up just going with flat irons. I think it was 160 shipped which I didn't think was too bad
