Old 08-13-2012, 05:42 PM   #1
AlWaysDrivin
Member#: 327668
1993 Legacy Turbo
Winestone
Subaru Stars No power on radio ignition wire
Did a little searchin around and couldnt find anything helpful so I'm postin here.
2003 Legacy L wagon
Recently purchased a new radio, which I attempted to install this morning. Wired up just the constant, ignition and ground wires to check that the radio would turn on. Got nothing, so I pulled out the multi-meter and discovered I'm getting no power through the ignition wire. Constant is reading good though. The fuse in the box isn't blown (none of them are) and there's no fuse on the back of the radio.
I was wondering (hoping) if there is another fuse hidden somewhere inbetween that could have gone? Any other ideas would be helpful as well, as I am quite lost at the moment as to what happened.
AlWaysDrivin is offline   Reply With Quote
Old 08-13-2012, 08:51 PM   #2
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
are you sure you have the right ignition wire?
fibuz is offline   Reply With Quote
Old 08-14-2012, 03:01 PM   #3
AlWaysDrivin
Member#: 327668
1993 Legacy Turbo
Winestone
yellow/green, yessir
Old 08-14-2012, 04:43 PM   #4
AlWaysDrivin
Member#: 327668
1993 Legacy Turbo
Winestone
Looks like my accessory port is also out as well
Old 08-14-2012, 09:19 PM   #5
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
check the voltage for the wire hitting the accessory port I'd say. If not, it's gotta be a fuse.
Old 08-15-2012, 08:56 AM   #6
98legwag
Member#: 160325
09 Legacy 3.0R
This may help as a reference. I am not 100% sure if the colors are the same.
http://www.crutchfield.com/p_1207089...77#details-tab
98legwag is offline   Reply With Quote
