Old 08-13-2012, 09:39 PM   #1
David LJ
Member#: 327875
Default H6 intake manifolds
Anyone know if the EG 3.3 or EZ 3.0/3.6 intake manifolds can be flipped so that it points forward? (Assumed that the alternator is moved off center). I'm contemplating a swap but don't want to cut into sheet metal on my 914.
David LJ is offline   Reply With Quote
Old 08-14-2012, 04:14 PM   #2
eg33GC
Member#: 206851
56 Belair
Pro Street
the angle of the upwards facing tb on the eg33 might be a clearance issue, but yes it can be flipped
eg33GC is offline   Reply With Quote
Old 08-15-2012, 12:25 AM   #3
grafton
Member#: 187936
07 WRB STi
given your username I'm inclined to think you'd know
grafton is offline   Reply With Quote
Old 08-15-2012, 02:29 PM   #4
eg33GC
Member#: 206851
56 Belair
Pro Street
alternatively if you want to fight the upswept angle, just cut the inner plenum section and flip that. the upwards rake won't be touched
Old 08-15-2012, 09:49 PM   #5
David LJ
Member#: 327875
Thanks EG33. Height will not be an issue, there will be at least 6" clearance vertically. Plenty of room both forward and above (for a CAI), but not on the flywheel side. I wanted to be sure that the TB could be rotated to the front pulley side.
