![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#1 |
Member#: 17845
Vehicle:2002 WRX WRB |
Can you use the spare tire with different wheels AS A SPARE TIRE. (if something goes wrong) Or would it not match up for the AWD?
#2 |
Member#: 1581
Vehicle:MY00 RS/STi7 MY01 RS Both Silverthorne |
Your aftermarket 17 inch wheel/tire combo should have the same overall diameter as the stock wheel/tire. So you should be fine using the spare. People seem to think that a 17 inch wheel will automatically make the tire's outer diameter larger, but if you get the correct sized tire it should be a very small difference. For example, a 215/45/17 tire is almost exactly the same height as the stock tire. If your question is about that little difference, I don't think it should matter as long as you keep the speed and distance to a minimum while driving on it. This is something you should do anyway. I can't tell you how many idiots I see weaving in and out of traffic doing 70 with a donut on.
#3 |
Member#: 5596
TXIC
Vehicle:2010 Honda Fit Sport Black |
Take a look at your spare tire. It's a temporary spare that WAY smaller in stock diameter than 205/55R16 anyways.
Switching to a 17, 18, 19, or 20" aftermarket wheels doesn't matter. It's still a temporary spare that you should use for the shortest distance to get your flat fixed or repaired. -Ray |
#4 |
Member#: 22230
Vehicle:2002 WRX Sport Wagon WR Blue Pearl |
Unless you have aftermarket front and rear brakes--then the spare is useless. I have the Subaru 4 pots up front. If I get a flat on one of my front tires I have to put the spare on one of my back wheels and put the back wheel on the front where the flat was.
I don't know if the Subaru rear 2 pots need a 7" or wider rim like the 4 pots but if they do then this would render the spare useless. -Chris |
#5 | |
Member#: 5039
South East
Vehicle:2007 Outback XT Grey 5-speed |
Maybe:
I cant speak to the other big brake kits but, I actually think the spare that came in my 97 GT is compatible with the Subaru 4pot kit. I saw an overseas ad for a spare that fit over four pots and the dimensions are the same as the spare in my car. Give it a shot, Amitofu, you may well be suprised. I think subaru to save expense seems to have spares classified as either 14" or 16," and the 16" ones seem to fit everything up to and including 4pots(not the Brembo 4pots tho.) subysouth |
#6 |
Member#: 22230
subysouth, I think the 4 pots differ from other brake upgrades because they don't need a bigger diameter rim they need a wider rim. I recall the spare being pretty narrow too.
Ooohhh, but wait... Maybe the spare has a really low offset--dare I say negative offset. Do they even make wheels with negative offsets? Maybe this would allow the pare to fit. I will try tomorrow or the next day. I hope I don't break anything ![]() -Chris |
#7 |
Member#: 5039
South East
I'm pretty sure its still a postive offset. Its the shape of the face of the rim that is the key. Just like the WRX wheels, the shape and the postion of the spokes is the problem. If there was a 16x6.5" wide Volk TE37 in 53 offset it would clear the 4pots because of the bumped out spokes. The design of the wheel is the key.
#8 |
Member#: 23786
Vehicle:2003 WRX 5-speed Yellow, Sonic Yellow... |
Will a ROTA 17" wheel fit in the spare tire well? If so, why not buy an extra wheel just to be sure.
Lenn |
#9 |
Member#: 10627
Vehicle:2002 WRX Sedan Platinum Silver Metallic |
Pretty sure a standard 17" wheel with tire will fit in the spare well.
However, it is much taller than the donut spare, so the board will not seat as it does with the OEM spare. You'll either have to custom fabricate something to fit over the taller spare, deal with a wobbly board and carpet, or just take out the board and carpet altogether. |
#10 |
Member#: 6598
Vehicle:2012 Mazdaspeed3 Crystal White Pearl |
I know that a stock rim and wheel will fit in the compartment of the wagon and the board fits back on. The only difference is that the storage tray must be left out.
#11 |
Member#: 5039
South East
now that the spare that came stock on my Legacy GT will clear four pots. I talked to a friend of mine overseas that has a Ver.4 STi which came stock with the 4pots on the front. His spare is a 16" one with the same tire size as mine. He showed me a pic and they look identical.
My spare tire size is 135/70-16 and the rim is significantly"bellied" out between the mounting face and the outer rim. I imagine any of the Subies with 16" wheels stock came with this spare. subysouth |
#12 | |
Member#: 6072
SCIC
Vehicle:01 Silver 2.5 RS 04 Silver WRX STi |
Chieh -- Chieh's Web - http://Chieh.CameraHacker.com/ |
| Thread Tools | |
| Display Modes | |
| When you go to Vista, are you upgrading? If so, whats your plan? | Davenow | Off-Topic | 49 | 12-19-2006 09:43 PM |
| What is the State ref and what do you have to do if sent there?? | AspenWhiteSTI | Southern California Impreza Club Forum -- SCIC | 17 | 06-16-2005 12:18 PM |
| New install: False floor, amp rack, spare tire box....and you get to keep your spare. | Kwyjibo | Car Audio, Video & Security | 10 | 04-17-2005 05:05 AM |
| Specs for the spare wheel and tire. | jimi900 | Tire & Wheel | 3 | 03-15-2004 10:18 AM |
| What Is The Lightest Wheel/Tire Combination In 16" | subarumantoo | Brakes, Steering & Suspension | 10 | 09-11-2001 11:14 PM |
