Old 09-03-2002, 05:56 PM   #1
2OHOH2WRX
Member#: 11888
Default Who can rebuild/upgrade an IHI VF23?
It appears that my IHI VF23 has sprung an oil leak after less that 15K miles of fairly mild use (that or it had it from when I first bought it 2nd-hand). It's bleeding a little bit of oil from the intake out port at idle, and occasionally puking it out at high boost (my Blitz FMIC, tubing, and intake manifold will need some serious cleaning, so I need info on that as well). I talked to Forced Performance, and was told to do some checks, which included checking the oil return line for clogging (wouldn't the oil pressure blow odd the rubber hose if it was clogged?), and checking the impeller shaft play. Since I already have a catch can keeping upstream oil out of the turbo, I think that the seal is compromised . They also said that they don't do IHI rebuilds.
So... who can rebuild and improve/upgrade an IHI turbo? How should I clean the FMIC and tubing (I can readily remove them), intake manifold (PITA to get out)?
2OHOH2WRX is offline   Reply With Quote
Old 09-03-2002, 05:59 PM   #2
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Default Rebuild IHIs
Talk to Reed @ Turbo Specialties.....
(205) 444-5011 He's very reasonable, and extremely knowledgeable. Tell him Steve Jordan sent you.
n2xlr8n is offline   Reply With Quote
Old 09-03-2002, 06:15 PM   #3
2OHOH2WRX
Member#: 11888
n2xlr8n - thanks for reminding me of them - I bought a fuel pump from them at one point, and was discussing their selection of WRX turbos. Josh just told me that ALL IHI turbos leak a little bit of oil. Used ones, new ones, it doesn't matter, they all leak a little bit "because of the oil pressure that those cars run at." He also reinforced removing the turbo and checking for play, and checking the return line for clogging.
Old 09-03-2002, 07:00 PM   #4
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Default VF23 rebuild
We're working on something that might REALLY interest you......I'll keep you posted
Old 09-04-2002, 08:25 PM   #5
pux888
Member#: 8356
02 STi swap
12 WRX limited
Talking
If someone could help with this, then what about beefing up a vf30
pux888 is offline   Reply With Quote
Old 09-04-2002, 08:29 PM   #6
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Default VF30
I'm not sure what you mean by "beefing up", but if that's possible, Turbo Specialties can do it for you....call 'em.
Old 09-04-2002, 09:54 PM   #7
EJ20K
Member#: 23058
STi v4 RA-M800ecu
STi7 shortblock & 1100kg.
Default Need parts to service a IHI VF turbo
Anyone know were can I get a set of new seal rings, for the compressor and turbine ends ?
I have 2 x IHI VF 24 turbos that need this rings to be changed, and cannot use them.
Thanx.
EJ20K is offline   Reply With Quote
Old 09-05-2002, 08:34 AM   #8
GoodFinder
Member#: 8943
2006 MINI + Corvette
Both Blue
Thanks for the reference to Turbo Specialties.
I'm changing out my turbo again soon and it will be helpful for me to have a list of such shops in case the person buying my old turbo wants to do any "work" to it first.
Regards,
GoodFinder
GoodFinder is offline   Reply With Quote
How to Upgrade an IHI Turbo Jakkim Newbies & FAQs 16 03-24-2010 09:04 PM
who can rebuild motors in atlanta dlowman South East Region Forum 14 01-27-2005 01:37 PM
Where can I repair an IHI turbo? Lachlan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 07-10-2004 08:49 AM
Selling a stock wrx transmission? know anyone who can rebuild one? LqSilver South East Region Forum 2 07-06-2004 01:47 AM
can i upgrade a IHI turbo?(shiv) tluzziracing Normally Aspirated Powertrain 19 12-01-2000 01:54 PM
