Old 08-15-2012, 03:40 AM   #1
notjustforshow
Member#: 143277
05 STI PPP OBP
1098, Z1000
Default Short WOT 4th Gear pull, advice needed
Hi All,
I would appreciate any advice and input on this pull. I realize I should lengthen my pull to WOT, as well as remove some of the items to monitor.
https://docs.google.com/spreadsheet/...mtOSkVqakZSa2c
Seems some really bad feedback knock. I've shaded the area where I begin my pull in 4th gear.
Of note, this is the Stage 2 91ACN (2005 STI) map, on 94 Canadian chevron gas.
Again, any input is appreciated
Cheers!
notjustforshow is offline   Reply With Quote
Old 08-15-2012, 04:28 AM   #2
mikeydrives1
Member#: 262117
2001 Forester
STi II type M
What turbo are you running.
Im a tuning newb (but with an open mind to learning) .... and i see that boost seems to come up, then fall off by a pound.... is 16lbs the target for this tune? Stock STi turbo shouldnt really struggle to hit and hold 17lbs as far as i know.
mikeydrives1 is offline   Reply With Quote
Old 08-15-2012, 04:31 AM   #3
notjustforshow
Member#: 143277
05 STI PPP OBP
1098, Z1000
stock turbo vf39
I basically didn't have a big enough stretch to stay at WOT 4th, so the usable data is not much :-(
Old 08-15-2012, 04:48 AM   #4
DontCare
Member#: 327422
2012 Subaru WRX
Plasma Blue Pearl
Needs moar wot
DontCare is offline   Reply With Quote
Old 08-15-2012, 04:50 AM   #5
DontCare
Member#: 327422
2012 Subaru WRX
Plasma Blue Pearl
Timing issue.
Old 08-15-2012, 04:56 AM   #6
DontCare
Member#: 327422
2012 Subaru WRX
Plasma Blue Pearl
Or target afr. Log afrs.
Old 08-15-2012, 05:09 AM   #7
notjustforshow
Member#: 143277
05 STI PPP OBP
1098, Z1000
Originally Posted by DontCare View Post
Needs moar wot
Timing issue.
Thank you, I will log AFR on my next one hopefully get a good length of road to WOT on.
