Old 08-15-2012, 10:17 AM   #1
Sleeper_RS
Member#: 305380
Default Head question
Noob question.... I have an 05 rs sohc. I believe it's ej251. Will the 253 sohc heads fit my car?
Sleeper_RS is offline   Reply With Quote
Old 08-26-2012, 10:56 PM   #2
zigzag801
Member#: 225784
2005 RS AW
Kawa Ninja
The 05 RS has an EJ253 in it. That's what mine has and it's the same engine from Subaru
zigzag801 is offline   Reply With Quote
Old 08-27-2012, 02:13 PM   #3
GrundleJuice
Member#: 165749
it's a 253 without the AVLS that the later 253's have.
I'm sure the heads would fit physically but mechanically/electronically it would require modification and some way to control the AVLS.
You should look into the coolant/oil passages and HG fitment if you get that far.
Old 08-27-2012, 08:12 PM   #4
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
OP only asked about 253 heads...never mentioned AVLS
geronimo81 is offline   Reply With Quote
Old 08-27-2012, 10:36 PM   #5
Sleeper_RS
Member#: 305380
Found out I have 253 block. We're good
