Old 09-03-2002, 07:16 PM   #1
xfactor834
Member#: 12506
Default UTEC & Hyperterminal Setup...Help!!!
I'm heavily considering ordering a UTEC now. Can someone run by me real quick how the Hyperterminal connection would work? I also have a Palm Vx so I can go both ways.
But with Hyperterminal, I'd have to make a new connection on my computer and dial into TXS' network?
Is there an FTP site for downloading the maps or just directly from their website?
Would it be easier via a Palm Vx or a computer?
Thanks for any info guys.
xfactor834 is offline   Reply With Quote
Old 09-03-2002, 07:32 PM   #2
SuperFreq
Member#: 3909
2002 Impreza WRX
Platnum Silver Metallic
No, I believe all you would have to do is setup what port you would be connecting through (com1/com2) and plug your UTEC into that port and connect.
Don't worry about it. I'm sure the manual has info on how to set it up.
SuperFreq is offline   Reply With Quote
Old 09-03-2002, 07:36 PM   #3
xfactor834
Member#: 12506
Thanks, because the only thing I was wondering about was that it's really not "with the flick of a switch" to change maps. I mean, isn't it a pain to access the UTEC every time to switch maps? Or disconnect it and bring it to my computer for downloading new maps?
In no way am I complaining - in fact - I'm buying a UTEC. I was just curious as to how it would all fit together.
Again, thanks for any info...and I'm sure as more and more users buy them and use them, we'll get more info.
Old 09-03-2002, 08:17 PM   #4
WRX300
Member#: 17974
I think there is a switch on the board for the maps....so if you have continual access to your ECU then yes.. if not then you will have to use a laptop or take out carpet...but how hard is it to run the *included* serial cable from the utec to the pass seat area....
~wrx300
WRX300 is offline   Reply With Quote
Old 09-03-2002, 10:09 PM   #5
Ryan23
Member#: 15116
2000 Ver6 STi Type-R
EJ257/GT35R
The current setup is not TOO much of a PITA. You pull the carpet up on the passenger side and turn a rotary switch on the board. The CEL will flash to tell you what map you're on when you key it on (and it will also tell you if your plugged in via laptop). "Flick of a switch" map selection is coming.
Ryan
I'm mainly using one map right now, 20 PSI feels great!
Ryan23 is offline   Reply With Quote
Old 09-04-2002, 12:30 AM   #6
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
As an ex-Link user, I ran the ribbon cable up through the carpet, and into the back side of the glove box. You want to tune - just open the glove box, grab the cable, plug into the laptop and tune away.
Its what I plan on doing with my Utec when it gets here in about a month
DarthChicken is offline   Reply With Quote
FS: Defi Setup & Rota Setup (Queens) WRX_JUNKi Tri-State Area Private Classifieds 44 06-06-2007 02:30 AM
utec delta hyperterminal problem slvr05rexr UTEC 7 06-02-2007 03:02 AM
Blitz DSBC EBC + UTEC Setup ??? Help xbcaraudio UTEC 3 03-23-2006 10:07 AM
60a relay? utec & NX. ... HELP! spankaveli Engine Management & Tuning 20 10-16-2005 02:19 PM
04/05 STi UTEC & WRX UTEC - Dyno Tuning Available Gruppe-S Bay Area Impreza Club Forum -- BAIC 6 01-19-2005 07:32 PM
