Old 08-15-2012, 07:30 PM   #1
KevsWRX21
Member#: 220326
2002 WRX JDM STi 2.0
Default HID Head Scratcher
So bought new headlights (depo) and new HID bulbs. Headlights have been adjusted, bulbs have been replaced twice now, ballast have been replaced, fuses/relays have been checked. I'm using Hella Ballast made in Germany! But for some reason my left headlight is super super bright. I have tired everything including grounding the bulb. Any ideas???
KevsWRX21 is offline   Reply With Quote
Old 08-15-2012, 07:33 PM   #2
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Uninstall PnP hid kit/crappy knockoff housings.
Install correct bulbs in correct housings.
Psychoreo is offline   Reply With Quote
Old 08-15-2012, 07:48 PM   #3
redrexmeister
Member#: 111692
04 wrx wagon
Did you try switching ballasts? If bulbs, ballasts are ok it 's probably harness u are using
redrexmeister is offline   Reply With Quote
Old 08-15-2012, 09:04 PM   #4
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
****ty halogen optics + pnp hid kit = doing it wrong.
if you like how the lights look, crack them open and do a retrofit.
My guess is one light has a bad projector or something out of alignment.
aerosaaber is offline   Reply With Quote
Old 08-15-2012, 11:47 PM   #5
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
Not that I disagree with the idea of doing it right (via proper retrofit). Isn't the depo headlight a replica of the USDM reflector low/high? If so, it's likely that the hid capsule from the kit + reflector geometry combination not having the minimum dimensional tolerance to at least be consistent from left to right units.
Like the ballast suggestion, try switching the hid capsules left & right to see if the problem is switched.
Either way, replace afterwards.
Post #13 in this thread seem to be a good example of stock my2008 halogen projectors with HID kit. Even though it is a projector, the difference between the halogen filament and hid capsule arc was enough to cause glare above the cutoff.
In some cases, there is no glare above the cutoff, but if you look at the concentration of light intensity below the cutoff (i.e. on the road and on the sides), putting a kit will result in a reduced lighting benefit.
satrya is offline   Reply With Quote
Old 08-16-2012, 11:26 AM   #6
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
oh lord, another HID kit...
Old 08-16-2012, 12:27 PM   #7
infinite012
Member#: 74392
2015 Forester
But guys! His ballasts are made in GERMANY!!! By HELLA!!!!!
infinite012 is offline   Reply With Quote
Old 08-16-2012, 03:34 PM   #8
Duvanator
Member#: 217257
2008 2.5i hatch
Satin White Wrap
not that I agree with hid kits, I will still try to help troubleshoot.
Are they bi-xenon? with a drop-down cutoff shield? the little actuator could be stuck down.
Are you running this off of factory wiring still? or a harness with a relay?
Battery is on left side, therfore less wire, less resistance, brighter output. since the factory wire is so thin. (not a likely scenario)
If they are not bi-xenon, then it could be a defector projector housing, defective lens, improperly seated lens.
Duvanator is offline   Reply With Quote
