Old 08-15-2012, 09:37 PM   #1
nubs1094
Member Sales Rating: (4)
Member#: 161849
2007 #300 of 800
bagged 94 S10 S.B.C.406
Default Whiteline HD Endlinks
These are crap. I have had them on my car for 2+ years now (07 sti), just had to replace them. They were clunking like crazy. A little embarrassing actually, very loud and people outside my car mentioned it. Replaced them with kart boy and no noise.
But Wait, There's More! (in your best infomercial voice)
They also rusted so badley into the control arm that wd40, PB blaster, heat, hammer, prybar, would not get the passenger side off. I actually drove around with the nut loosened for a few days before the vibration and harshness of road travel broke it loose. They obviously don't have salt in austrailia where whiteline is made.
On another note, I also have their sway-bars and they seem to do just fine. I painted them before install because I noticed used ones often look like the outside layer had rusted off. The paint thing seems to work well thus far after 2 winters
nubs1094 is offline   Reply With Quote
Old 08-17-2012, 12:04 AM   #2
Fierysun
Member Sales Rating: (104)
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
Pic's?
Fierysun is offline   Reply With Quote
Old 11-08-2012, 02:14 PM   #3
1wrxtra
Member#: 316364
2012 WRX
I installed mine about a month ago and they clunk like crazy... I am going to take another look under there to see what's up.
The last time I checked I noticed that the brackets they give you to mount the bottom of the endlink to the frame were loose and jiggling back and forth when I was driving.
This time I have a bunch of washers that I'm going to install to reduce the amount of movement the bracket has... I'm hoping this fixes the issue. I greased the crap out of the bushings so I doubt they are the problem, but I don't believe it should be necessary to tighten the lock nuts every few weeks to prevent the clunks.
If this doesn't work, I'm going with the Ralliteks.
Update:
I took another look at the brackets, they don't entirely fill out the gap in the control arm where they mount. I solved the problem by jamming a stainless steel washer in between the bracket and control arm. No more movement side to side, or front to back. No more noise.
Hooray.
1wrxtra is offline   Reply With Quote
