Old 05-03-2013, 09:13 AM   #351
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
concillian - thanks for posting the update, glad to hear you are enjoying the setup. ID1000's on E85 sounds spot on. The more experience and time were getting with the EFR's its easy to see on the 2.0L EJ207, the 6758 is an excellent match (up to ~22-24psi or so). For the 2.5L engines at 7000rpm once you get above 18+ psi at redline you are running out of compressor map so the 7163 will be a great choice once its available
Full-Race Geoff is offline   Reply With Quote
Old 05-03-2013, 09:18 AM   #352
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
HERE is a simple matchbot for 2.0L and 6758, take a look if you have a minute. you can see this is a great match as you are operating in the meat of the compressor map efficiency islands. Also its calculating 411hp peak at 7000rpm and 344tq at 4000rpm
Old 05-03-2013, 12:07 PM   #353
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Geoff, what's the availability of the stiffer CRV springs for the EFR turbos. I get a little CRV flutter noise with my TS kit at part throttle and I need a stiffer spring. I guess I can try shimming it but if you guys can get me a spring I'll take that too.
Old 05-03-2013, 12:28 PM   #354
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
BW's stiffer CRV springs arrived this morning!
Old 05-03-2013, 12:34 PM   #355
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Calling
Old 05-03-2013, 01:58 PM   #356
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
Old 05-04-2013, 09:44 AM   #357
vinny.dtw
Member#: 139718
2011 STi, E85 1.5xtr
WRB, Show and a little GO
Geoff, would you happen to know if the upcoming 7163 is the same dimension as the 6758?
vinny.dtw is offline   Reply With Quote
Old 05-04-2013, 09:54 AM   #358
3mlwhly
Member#: 217648
01 2.5rs
When is this turbo being released
3mlwhly is offline   Reply With Quote
Old 05-04-2013, 12:29 PM   #359
rexblake
Member#: 178426
2010 S4
Gray
I was informed the turbo "might be released by the end of the summer". I'm really excited for what the 7163 can do too. The 7064 has been a little disappointing to me in the higher rpm. Granted, I have only looked at one dyno and know nothing about the car it's on.
rexblake is offline   Reply With Quote
Old 05-04-2013, 12:47 PM   #360
3mlwhly
Member#: 217648
01 2.5rs
I can't wait to see more results... I'm really hoping this this thing can get to 450whp on 91 gas with built 2.5l motor, in northern cali there's not a lot of e85 stations... This would be great and total sleeper if you get pulled over
Old 05-04-2013, 03:05 PM   #361
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
uhh... not gonna happen, sorry. Look at the first post, the 7163 is like 350 on 91. That car was fairly stock, so with some mods you might get another 10? 15? Maybe. 450? Not a chance.
A built motor doesn't really buy you too much in terms of power. 450 on 91 is simply going to take a much larger turbo.
Concillian is offline   Reply With Quote
Old 05-04-2013, 03:37 PM   #362
3mlwhly
Member#: 217648
01 2.5rs
I was pretty certain it wasnt going to happen.... It was more like a wish... I do appreciate you letting me down gently... Haha
Old 05-04-2013, 03:41 PM   #363
3mlwhly
Member#: 217648
01 2.5rs
I was thinking more than 15 though with porting +1 valves, big fmic, big cams, 8000 redline, along with all the hoses and piping for high flow and short piping for quick spool... I don't think I was specific enough when I said built motor... Any input would be greatly appreciated
Old 05-04-2013, 04:28 PM   #364
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
No matter what you do to the engine, the turbo won't flow enough air for 450 on 91. The stock cams and valves are reasonably efficient for a turbo the size of the 7163, and you're going to gain very little from that kind of headwork on a 50-55 lb/ min turbo (I don't know exactly what flow the 7163 is, but probably in that ballpark.) This is HTA green-ish max flow (53 lb/min I think). Go find some external gate HTA green dynos on 91 and see where you can be. The 7163 might have some different response, but peak flow is peak flow. You're not going to find too many HTA green charts on pump in the 400s.
Old 05-04-2013, 04:38 PM   #365
3mlwhly
Member#: 217648
01 2.5rs
Maybe I should look into the bigger version then
Old 05-04-2013, 05:37 PM   #366
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Yeah, look more at 7670 to get closer.
Here is a thread with a 7670 with built engine, cams and +1 valves
http://forums.nasioc.com/forums/show....php?t=2041557
20psi on 92 octane was under 450, but I'm sure that was a pretty safe and sane map for no meth, since his meth map is what he'll use when he pushes it. You'll need to push more boost on worse gas. Straight 91oct is not easy to make 450 with... takes a pretty big turbo.
Methanol injection will be much easier to hit that, and the 7064 might be more doable with help from meth.
Old 05-07-2013, 08:16 PM   #367
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
yes - the 7163 is identical outer dimensions as 6758 and 6258
"end of summer" is the current eta for 7163. in borgwarner time they are tricky becuase it could be the end of summer .. of 2017
i think that is possible, but would be a lot easier and safer to do with the 8374 twinscroll! thats what im running on my built 2.0L evo for 450whp on 91 octane and love it
the 7163 compressor map (not publically released yet) flows ~60lb/min at full tilt... this thing packs a big punch in small package and able to do it in stock location is a huge bonus (especially for the Cali crowd who can not go rotated for fear of impound) FYI: paul's 7163 in this thread was a very early prototype, one of 4 evolutions, and only capable of ~51.5lb/min at full tilt. he was dynoing with stock TMIC, cat and 2.5" exhaust in place, more room to go for certain
Old 05-07-2013, 08:25 PM   #368
3mlwhly
Member#: 217648
01 2.5rs
Thank you for a little more info... I was a little suprised when he said that... What does that 84 spool at on the 2.0l? My biggest concern is drive ability on the street although I do want to race it often.. :-)
Old 05-09-2013, 08:17 PM   #369
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
all of the B1 frame singlescroll EFR and B2 frame twinscroll EFR turbos exhibit excellent street manners. For any subaru application, the first question to answer is "Stock location or rotated" - once you know that, then B1 frame singlescroll or B2 frame twinscroll choice is made for you and you can use the borgwarner matchbot to solve for your power, boost and shaft speed targets. Its really surprisingly simple to use, just looks intimidating
Old 05-10-2013, 09:57 AM   #370
Turbo zxy
Member#: 356038
Default efr 7163 in matchbot
some body of this great site knows when efr 7163 is going to be available in matchbot?
Turbo zxy is offline   Reply With Quote
Old 05-10-2013, 06:15 PM   #371
3mlwhly
Member#: 217648
01 2.5rs
I would prefer stock location, But I don't want to be hindered by that. If I go by matchbox I should probaby go b3 frame for the top end I want but ill probably go with the 7163 and see were I land I do love instant spool so I thank this is good middle ground at a price that won't make my wife kill me (although that probably is enough to do that anyways) lots of good info on here and thanks for all the input, still waiting to see when its released and someone REALLY maxes it out on pump gas to see what it can do
Old 05-18-2013, 05:33 PM   #372
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
quick question on this. it says its requiring about 225 lb/hr of fuel at 7k rpms for this turbo. thats like 2300 cc/min fuel injectors. that doesnt seem accurate to me. i would think on pump fuel you could run ID1000s with the 7163 let alone the 6758, i guess i was just trying to use it to gauge how much injector i would need to run 20 psi on e85. looking to bump up the 4-6k boost a bit to 23 to get more torque as well. seems like a 3psi increase for those 2k rpms will keep torque above 350 with a max of 375ish "373.41 354. 354.85" <-from the matchbot.
WhiteBgeye02 is offline   Reply With Quote
Old 05-18-2013, 05:52 PM   #373
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Well, just put in 21psi into Geoff's matchbot. That was between 95 and 100% IDC on ID1000s, which scale out more like 900ish, you can ratio consumption from there.
Also, keep in mind there are 4 injectors 2300cc/min is divided among the injectors.
Based on my torque curve, if flow held up perfect, you're looking at an additional ~17% at most at 7kRPM. So sizing ~1100cc should give a little headroom. Consequently this is around the same flow that the DW300 / Aeromotive 340 run out of steam. More than ~1100cc you need to look into the whole fuel system. Boost-a-pump or the bigger Walbro and an FPR at the very least.
Old 05-18-2013, 11:10 PM   #374
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
oh thats right. long day and was just trying to analyze the whole matchbot w/o enough sleep. I only have a walbro255 so its in need of an upgrade anyways. idk how soon its going to happen for me. prob when the vf37 dies and go from there.
when you say 17% your talking hp over what the chart is showing or what you are showing for torque? A nice broad torque curve is what would work best for autox and if i can get it up around 350wtq and keep it there til 7k rpms it will be plenty fast. the whp isnt really a worry but i know with this turbo that if I want 400whp it will get there.
as far as injectors i noticed you ran the same injectors and were getting close to 100%idc. 98% if i recall correctly at 20psi. what afr do you run on e85? i could prob turn the pressure up a tad to make the headroom but like you said 1100 woudl probably be safer.
Old 05-19-2013, 01:45 AM   #375
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
For an "ideal" engine / turbo / head / cam / intercooler combo, a given boost pressure will result in a given torque regardless of RPM.
That's not reality, at some point the system runs out of efficiency and torque drops off. This can be due to any component or a combination, but the result is the same, torque starts tapering off. In my case, torque at 7000 RPM is around 15-17% lower on airboy at 7000 RPM than it is where torque is relatively flat.
Your "best case" scenario, then, is 15-17% more torque at 7000 RPM, and that will require a directly proportional amount of fuel.
Any more than that requires additional boost pressure or displacement.
In reality it will be a little less than that, so there's your margin.
350 wtq at 7k is 350 * 7000/5252 = 465 HP. 400 HP is 300 wtq at 7k.
I'm running 11.6/11.7 (gas equivalent) AFR.
You're at the edge of a DW300 at 1050-1100cc at base pressure, there's no room to bump the pressure. Check the flow sheet for the pump. Fuel pressure increases result in pumping capability decreasing. If you want to run that kind of flow with a Wally 255, you need to jack up the voltage with a device like a boost-a-pump. Fuel pumps increase current too when voltage goes up, so power and flow increases nicely with even small voltage increase.
Check the sheet for DW300, which has flow charts at three different voltages (13.5, 16 and 18 volts)
http://www.deatschwerks.com/resource...fuel-pump-tech
21 psi boost + base pressure 43.5 is around 65psi total pressure, but round that to 70 to give some loss for the lines and fittings and such.
70 psi is 250 L / hr (4167 cc/min = 1042 cc/min injectors).
16v is 320 L / hr (1333 cc/min injectors)
19% voltage increase, but 70psi flow increases 28%. This is why the boost-a-pump works well to give additional flow. small voltage increases yield significant flow capacity increase.
So for fueling, roughly 4 bar fuel pressure will allow the ID1000s to flow in that range (1050ish). You'll need a pump that can flow ~250-270 L / hr at 80-85 psi, and based on the Walbro flow tests I've seen, even with a boost-a-pump it'll probably fall short of that, since the Walbro falls off pretty sharply at high pressures, so you'll likely need either a DW300 with a boost-a-pump or one of the bigger Walbros (416 I think? whatever their big E85 pump is) direct wired.
Also, I'm not sure why you're expecting a vf37 OEM turbo to die anytime soon. There are lots of vf cars running WELL over 100k miles. You might be waiting a long time to upgrade if you're gonna wait for that to die.
