Old 09-17-2013, 11:04 PM   #451
3mlwhly
Member#: 217648
01 2.5rs
Wow are the big numbers from efr
3mlwhly is offline   Reply With Quote
Old 09-17-2013, 11:38 PM   #452
Leafy
Member#: 330625
2006 WRX
Not really all that big numbers wise. Check out the most recent version of the compressor map, I would expect to hit 480 whp on a rwd car on e85 with one now, 450 on e85 on a subaru.
Leafy is offline   Reply With Quote
Old 09-18-2013, 06:04 AM   #453
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Originally Posted by RobSTI89 View Post
Me-6758 + blouch 20gxtr + stock sti
Were these all on the same car, same setup?
Would be nice to see ALL of this plot. It looks like the pulls were definitely started at different RPMs. Boost and AFR would definitely add to comparative data. What exhaust housings were on the BW & Blouch?
KillerBMotorsport is offline   Reply With Quote
Old 09-18-2013, 07:17 AM   #454
RobSTI89
Member#: 225268
2005 STI
Different cars same dyno. All cars started at 2400rpm.
Blouch 20gxtr is a 8cm on a 2012 sti with tmic built bottom end stock cams.
So it has a tmic and dual avcs to help spool and didn't even come close.
EFR FTW
RobSTI89 is offline   Reply With Quote
Old 09-18-2013, 07:17 AM   #455
Leafy
Member#: 330625
2006 WRX
The 6758 can only be had with the 0.64AR T2 flanged IWG housing currently. In a little bit you should be able to order it with the bigger T4 twin scroll housing, but I really dont see how there would be any gains going to the bigger housing.
Old 09-18-2013, 07:29 AM   #456
RobSTI89
Member#: 225268
2005 STI
The bigger compressor housing will give you more CFM`S at higher rpmīs.
Old 09-18-2013, 07:38 AM   #457
Leafy
Member#: 330625
2006 WRX
Obviously. But right now there isnt a bigger compressor that fits in the stock location, with the 7163 comes out there will be, and currently BW has said that one will come with both the .64ar T2 housing and the TS T4 housing. I expect that the T2 housing will actually have an impact on max power with the 71mm compressor, I don't think it has an impact on the 67mm compressor.
Old 09-18-2013, 08:04 AM   #458
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
EFR FTW
OK, thanks.
AFR, boost and fuels?
Any way you can lay the stage II over that graph too? Make for a much better comparison that stock
Old 09-18-2013, 08:25 AM   #459
RobSTI89
Member#: 225268
2005 STI
I am going to make my own thread this weekend I don't wanna clog this one up. I will have 1/4 miles times too.
I will have tuner get me some more graphs too.
Rob
Old 09-18-2013, 10:46 AM   #460
visibiliti
Member#: 211987
2004 STi
Thanks for the influx of data, Rob.
That 6758 is looking pretty awesome, and I can't wait to see some comparisons between 6758 and the new 7163 once someone finally gets their hands on one!
visibiliti is offline   Reply With Quote
Old 09-18-2013, 10:58 AM   #461
RobSTI89
Member#: 225268
2005 STI
Well maybe full race will let me test one and we can compare them !
Old 09-18-2013, 11:00 AM   #462
Quiksmith
Member#: 266230
2006 WRX STI
Subscribed!
Quiksmith is offline   Reply With Quote
Old 09-18-2013, 01:26 PM   #463
NA STI
Member#: 285083
2006 STi
Yeah Rob I think your car is better built and setup for a 7163 with the cams and fullly built head and all. Also id bet that with stock heads and cams the 6758 would spool just like stock and would hold 24-25psi all the way thru redline. This should have no problems making 450whp on good E85, 25psi, and all the normal bolt ons
Whats the news on the 7163 we were supposed to hear this past weekend or this week?
NA STI is offline   Reply With Quote
Old 09-18-2013, 07:13 PM   #464
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Waiting for email digital copy of graph best I have. That shows a 2012 sti stage 2 and my car.
This matches with my experience in the EJ207. I tuned my car (EFR6758) and this summer I was able to tune as stock turbo vf30 ver 7 and the spool is very similar between the two. After the turbos are spooled the similarities end. The 6758 flows a TON more than a vf30. Nothing comes close to the spool for power, in my experience.
Concillian is offline   Reply With Quote
Old 09-26-2013, 10:18 PM   #465
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
I am going to make my own thread this weekend I don't wanna clog this one up. I will have 1/4 miles times too. I will have tuner get me some more graphs too.
good stuff rob! post a link when you get the thread online
thanks for following up with a long term review - I love hearing from customers a few months later that your still in love with the setup
EFR's have never been a "big dyno numbers" turbo... Area-under-the-curve and response is where they excel
as usual, BW wont make any promises on delivery dates for the 7163. Demand is high and production is not huge, so we aren't making any announcements anywhere else online... if youre on the reservation list you will get a call as soon as we have confirmation from BW the units are on the way. However we curently have the 6258, 6758, 7064, 7670, 8374 and 9180 all in stock and they are no slouches !!
Leafy and rob, you guys are confused. The new larger 0.80 a/r housings that come out next year are hotside turbine housings only. There was no change to compressor housing - all B1 EFR turbos use the same part (6258, 6758, 7163). The 7163 will only available with the larger 0.80 a/r turbine housing only, it will not be available as 0.64 a/r
Full-Race Geoff is offline   Reply With Quote
Old 09-26-2013, 10:59 PM   #466
Leafy
Member#: 330625
2006 WRX
I know the compressor and center housings are the same between all B1 frame turbos, but last I heard the 7163 was coming out with both turbine sizes (.64AR SS and .92AR TS). Will the bigger turbine housing (.80AR) have the same form factor? IE if you already have a 6758 setup, will the 7163 be plug and play?
And whats the deal with the .92AR Twin Scroll housing?
Old 09-26-2013, 11:18 PM   #467
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
the B1 EFR turbos -- such as 6258 and 6758 are singlescroll 0.64 a/r only. They have the identical form factor to 7163 singlescroll 0.80 a/r, all are plug-and-play for one another.
0.92 a/r twinscroll is only for the B2 EFR turbos. i loooove my 8374 with this housing
there will be a 0.84 a/r twinscroll for the B1 turbos eventually, but we have no clue how far out BorgWarner-time is with that... could be a number of months
Old 09-26-2013, 11:20 PM   #468
Leafy
Member#: 330625
2006 WRX
Ah ok. BW really needs to update their site, it still shows the B1 frame turbos with the .92AR TS housings as possible. Of course it also shows the 6255 as a thing too.
Old 09-27-2013, 04:21 PM   #469
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
i will relay the message
Originally Posted by KillerBMotorsport View Post
Were these all on the same car, same setup? Would be nice to see ALL of this plot.
hey hey - these EFR turbos could work well on your killerB turbokits too
Old 09-27-2013, 04:36 PM   #470
Leafy
Member#: 330625
2006 WRX
Ahh, but the KB low mount kit is setup for a T3 twin scroll.
Old 09-27-2013, 04:38 PM   #471
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
^^nothing a T4 flange cant solve
Old 09-27-2013, 04:39 PM   #472
Leafy
Member#: 330625
2006 WRX
And needing to cut 3" off the down pipe and use the GT3" v-band.
Old 09-27-2013, 04:47 PM   #473
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
1.05 a/r external WG borgwarner EFR turbos do not require the downpipe to be shortened... thats only if you are using the IWG
also - all EFR turbos use the same vband as the 'GT30/35/40 3" vband' (which is the same as Tial)
Old 10-01-2013, 12:17 PM   #474
Obababoy
Member#: 158888
2011 STi EFR 7163!
07 GT30 WRX sold :/
Date on 7163?
So really, is Turbo Inlet size negligible?
Will the 7163 only be a 2.5 inch?
Im looking to purchase supporting mods now so I need to pick a good turbo inlet/intake.
Also why is the stock location kit over $1500 when it is essentially a glorified Downpipe(Catless) and up pipe? I am not trying to complain as much as I am trying to find an explanation of costs
Obababoy is offline   Reply With Quote
Old 10-01-2013, 01:58 PM   #475
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
there is no "answer" to the question of whether inlet size is negligible, for some turbos which can enter the surge region - yes it matters. the B1 EFRs were designed with extremely wide comp maps and surge areas far from operating points, such that it doesnt benefit anything to have a larger comp housing
7163 production is going on through october. We are not going to list them on our site until the reservation lists are filled, too many phone calls about them as it is. people on our reservation lists will be getting the turbos first, thanks everyone for your patience still a few weeks away but its happening. I will ask if i can post a couple photos
btw all the other EFR turbos are currently in stock and those 6758s haul the mail!! dont underestimate it
